XFoil Reynolds Number Calculations
The discussion revolves around the calculation and application of the Reynolds Number in XFoil for validating experimental data from a wind tunnel. Participants explore the implications of using different values for freestream velocity, viscosity, and chord length in the context of computational analysis.
  • Experimental/applied
  • One participant questions whether the Reynolds Number should be calculated using experimental values or standard sea level conditions, suggesting a discrepancy in the expected input for XFoil.
  • Another participant clarifies that the freestream velocity and viscosity should reflect the wind tunnel conditions rather than average sea level values.
  • A participant seeks confirmation on whether to enter the Reynolds Number as calculated based on a unit chord length or to adjust it according to the actual chord length used in the experiment.
  • One participant expresses confusion about the appropriate method for entering the Reynolds Number, ultimately suggesting that it should remain consistent to ensure proper scaling in the simulation.
Participants exhibit disagreement regarding the appropriate values to use for calculating the Reynolds Number in XFoil, particularly whether to use experimental or sea level conditions. The discussion remains unresolved as different viewpoints are presented without consensus.
There are limitations regarding the assumptions made about the chord length and the conditions under which the Reynolds Number is calculated. The implications of using unit chord versus actual chord length in the context of XFoil are also not fully resolved.
Thusithatck
Can someone explain to me how XFoil calculates the Reynolds Number for computational analysis. I have the XFoil manual which explains the method used in calculating the Reynolds Number. But what I don't understand is that it says that the "Reynolds Number is defined with the freestream velocity and viscosity, and an implied unit chord.
My experimental data are,
Re,chord = 380,000
V = 16.67 m/s
T = 293 K
P = 101325 Pa
Viscosity = 1.813 e-5 kg/ms
Density = 1.205 kg/m3
above values are extracted from an experiment, where I'm intending to use XFoil for the validation of experimental data. According to the Reynolds Number equation mentioned below where,
Re = (V x density x chord) / viscosity
if the implied chord is taken as a unit, then the Reynolds number I should enter in XFoil should be 1107872 (not 380,000), approximately. Having said that, when it say freestream velocity and viscosity, does it mean I should use the velocity as 16.67 m/s (which is the correct speed of the wind tunnel during the experiment) and the sea level viscosity which is 1.78 e-5 (not 1.813 e-5, which is the correct density at the wind tunnel during the experiment).
Since the force coefficients (CL, CD, CM) are calculated (in XFoil) by normalizing the forces with ONLY the freestream dynamic pressure, which is given in below equation,
q = 0.5 x density x V2
CL = L / q
CD = D / q
Cm = M / q
where the only input parameter options available in XFoil are Reynolds Number and the Mach Number. Hence I believe that velocity in the dynamic pressure equation above is calculated from the Reynold number equation and the other parameters such as viscosity and density are taken as sea level conditions (not the experimental values). Therefore the Reynolds number has to be adjusted by using sea level values. Is this is correct ??
Free stream velocity and viscosity are the wind tunnel conditions in the free stream, not average sea level values.
When XFoil assumes a unit chord length, that means it is essentially outputting the unit Reynolds number. Just multiply it by your actual chord length to compare with your wind tunnel results.
Just to confirm, my wind tunnel experimental Reynolds number is 380,000. So when I specify the Reynolds number in XFoil using the "Re" command, do I need to enter it as 1107872 (Reynolds number based on a UNIT chord) which will be 380,000 when multiplied by 0.343m (actual chord length).
Or...
multiply 380,000 (Reynolds number during the experiment) by 0.343m, which would give 130,340 as the Reynolds number.
The input (airfoil section used for the analysis) airfoil co-ordinate file has an unit chord (x/c = 1), not 0.343m as well.
I have confused myself here actually. Reynolds number is not something that should be played with. Just leave the Reynolds number the same in both cases so that it properly scales. Sorry about that. I have been thinking bass ackwards today.
You are essentially simulating the wing in XFoil at 1m chord length and comparing to a scaled-down test in the tunnel. The correct way to do that is by matching Reynolds number.
  • · Replies 17 ·
16K
