Troubleshooting Computer Crashes After Hardware Upgrade
The forum discussion centers on troubleshooting computer crashes following a hardware upgrade, specifically after installing Windows XP Pro on an older Intel Pentium III system. Users report issues such as system instability and event viewer warnings related to ACPI BIOS and hard drive failures. Recommendations include removing additional RAM, performing a clean install of Windows XP, updating drivers and BIOS, and utilizing diagnostic tools like scandisk and S.M.A.R.T. technology to assess hard drive health. Users emphasize the importance of backing up data and suggest using a new hard drive as the primary drive for better stability.
  • Understanding of Windows XP Pro installation and configuration
  • Familiarity with computer hardware components, including RAM and hard drives
  • Knowledge of BIOS settings and updates
  • Experience with diagnostic tools like scandisk and S.M.A.R.T.
  • Research how to perform a clean installation of Windows XP Pro
  • Learn about updating BIOS and drivers for Intel Pentium III systems
  • Explore the use of S.M.A.R.T. diagnostics for hard drive health assessment
  • Investigate methods for safely removing and testing RAM modules
This discussion is beneficial for computer technicians, IT support professionals, and users experiencing system instability after hardware upgrades, particularly those using older systems with Windows XP Pro.
qwpoi
I recently installed XP Pro onto my comp, and added a 2nd hard drive, and upgraded my RAM. The computer started crashing everytime I'd run virus scan, and on and off when I do other operations, usually when trying to access my 2nd hard drive. The event viewer says that ACPI BIOS is attempting to read from an illegal port address which can lead to system instability blah blah. I looked online and there were a number of different solutions and I am not sure which one to follow. I won't list them here as there are a couple of diff. options--I just wanted to know if you guys had some input on what I should do to fix this problem.
Thanks.
Computer science news on Phys.org
What is your system's configuration ?
What m/board? What CPU ?
Heh. I'm afraid I don't know my computer too well, and have no idea what motherboard I am using. It is an Intel Pentium III processor, 727 MHz.
I'm not sure what you mean by configuration.
I looked in properties and it says that the manuf. of my motherboard is Standard System device... the driver having been provided by microsoft.
Computer is cheap, buy a new one, you can get a good AMD-athlon with as low as 400 dollar.
Go to buy it !
Try this:
http://www.abspc.com/index.asp
Try and narrow your problem down.
First, remove the extra ram, boot and see if you get the same issues. If you do, try putting the ram back in and remove the hard drive and see if that clears it up.
Did you install XP onto a blank drive, or did you upgrade? If you upgraded, I would HIGHLY suggest backing up your important data and formatting the drive. A clean windows install is a happy install.
Another thing you should do even if you manage to get it fixed is to search for updated drivers and BIOS. Check your motherboard manufacturer's site (or computer mfc. site, if you are using a pre-built computer) for updates to bios. If you are using a computer you built (or a friend built - anything not brand name) you will have to figure out what devices you are using and search their respective mfc sites for drivers. If you are using brand name, just go to your computer mfc site and get them there.
Ho Ho Ho
Go to buy it !
Now, who was the one complaining to Greg of having a lack of money who now tells another "Go to buy it" ! hahaha
https://www.physicsforums.com/showthread.php?s=&postid=37772#post37772
Oh yeah, before I forget...
qwpoi,
Considering gave you sound advice so give it a go.
You see, you installed more than one item which can add ambiguity to the problem. By running the computer with one new component at a time you are better able to see what might be causing the problem.
Good luck.
Heh, buy a new computer? You're talking to a poor college student.
I will try narrowing the problem down, though after some research online I found that a ton of other ppl who install xp pro have been getting this error message, so a big part of me thinks it's the new operating system adapting to an older computer. Their suggestions were sort of confusing though.
The installation was done over an old OS, I believe I formatted the disk before installing the new one though, so it would qualify as a clean install.
WISH ME LUCK.
sigh. (A futile effort at optimism and cheerfulness.)
install linux and see how.
Huh? See how to do what?
(I must be going crazy, because I thought I had already posted a reply, but upon checking the thread, there was not one here.)
And another questions is that I have been receiving warnings in my Event Viewer, telling me that my hard drive has predicted its own failure, and I should replace it ASAP. (How ingenious,I had no idea that they could predict their own deaths...) My question is that, as long as I have everything backed up (which I do,) can I just keep running this hard drive till it actually fails?
Yes, as long as your data is saved elsewhere you can run it into the ground.
You have installed XP Pro SP1, right? That should be your first step, if you think it is an XP problems. The run windows update and download the huge backlog of updates...
For those who dislike MS, please refrain from posting about the huge backlog of updates for Windows :wink:
I have 2 suggestions for you.
First run a complete scandisk (including surface scan) on your harddrive that is predicting failure. You probably have a lot of damaged sectors, scandisk should be able to find them and mark them so that they aren't used. This should help a little bit.
Second, and more importantly, connect your new harddrive so that it is the master. To do this just remove the jumper on your first harddrive and put it on the slave position, then on the new one remove the jumper and put it on the master position. They both must be on the same IDE interface (same cable). Now your new harddrive will be your C: drive. Reformat and reinstall windows on this harddrive. (I can elaborate if necessary.)
You can keep using the soon-to-fail harddrive until it actually fails, but I'd just use it for nonimportant data, such as videogames and applications that you don't use too often, so that when it fails you don't lose anything vital. Or you could just remove it altogether and have one less thing that could cause you problems. I definitely would not use it to hold your operating system.
Well actually, all vital information is kept on my 2nd hard drive anyway...I suppose I could just make a new partition and install the OS there after making it the master...
I did run scandisk on the apparently damaged drive and it didn't tell me anything about damaged sectors. This is a long shot, but could it be predicting imminent failure due to the fact that I had to rig up a creative way of keepign it in the disk bay using strings, because the bay that my comp. came with didn't have a spot to hold a second hard drive, and, hypothetically, if the strings broke or something (I haven't gone inside the comp to check this yet), then it would be hanging in a pretty diagonal fashion...?
Someone else also told me to run a stress test on the disk in addition to doign scandisk, but I can't find that option in the XP menus.
Depending on the drive mfc, they normally have a diagnostic program you can run. Western Digital drives, for instance, include a diagnostic disk.
Check the mfc website and see if they have one - best way to find out if there are truly errors.
I believe the failure prediction is from the S.M.A.R.T. (Self-Monitoring And Reporting Technology) feature on your system board/harddrive.
See this link for more info on the S.M.A.R.T. feature and what it monitors and can predict:
http://www.pcguide.com/ref/hdd/perf/qual/features_SMART.htm
The last paragraph states:
If you experience a SMART alert using your drive, you should immediately stop using it and contact your drive manufacturer's technical support department for instructions. Some companies consider a SMART alert sufficient evidence that the drive is bad, and will immediately issue an RMA for its replacement; others require other steps to be performed, such as running diagnostic software on the drive. In no event should you ignore the alert. Sometimes I see people asking others "how they can turn off those annoying SMART messages" on their PCs. Doing that is, well, like putting electrical tape over your car's oil pressure light so it won't bother you while you're driving! :^)
Sounds like good advice to me.
(edit:)P.S. The site link above has an excellent comprehensive BIOS guide. It starts here: http://www.pcguide.com/ref/mbsys/bios/
thanks for your help guys. I'm actually leaving the country for the summer and my computer is not coming with me...is this something that I should take care of before I leave, or can it just sit in my room, turned off, until I return?
It will be fine just sitting around, as long as it remains off.
I think XP is great, ME is the troublemaker. I had ME for 2 years and my computer would freeze all the time and eventually the whole system crashed, I lost everything. It fried my sound system right off the computer. I just got a brand new computer with XP on it and I have had no problems.
  • · Replies 42 ·
9K
  • Sticky
