Yellow Epoxy Like Material on PCB?
  • Thread starter Thread starter BuddyBoy
    Pcb
The discussion centers around a yellow epoxy-like material found on a PCB, speculated to be a two-part polyurethane used for protection against vibration and environmental damage. Participants express curiosity about its removal without damaging the PCB, with suggestions including paint strippers like dichloromethane. Concerns are raised about the safety of using such chemicals, especially without proper equipment and experience. The voltage of the PCB is clarified as 12 V DC, indicating it is not high voltage. Understanding the material's composition is essential for determining the safest removal method.
BuddyBoy
I've seen the black epoxy on various pcbs to encapsulate it. I've also seen plenty of times a Clear coating. But this is my first time seeing this yellow stuff? Any idea what it is?
My guess would be a two part polyurethane, being used there to protect surface components from vibration, physical and environmental damage.
Hey thanks. Any idea on how to remove it without damaging the PCB or what's underneath it?
Why do you want to remove it?
If you knew exactly what it was, you could probably find out what the recommended removal chemical is. But as @Baluncore implies, such chemicals are usually pretty dangerous and should not be used unless you have access to a chemical fume hood and experience using hazardous chemicals.
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
