mheslep
- 714
If you knew this, and that the Volt can go 40 miles on batteries alone, then what was the point of your #1 "GM doesn't produce a single electric car (Volt is not an EV), what the hell is GE going to buy?"?Topher925 said:I entirely understand its design. FYI, parallel hybrids can operate without the ICE engine in the loop as well. They just can't drive as far with battery power alone due to a smaller battery pack, not due to limitations of concept.
Drive away?And what will you do after that, assuming you are no where near an electric power outlet or space heater?
Well I'm not an electrochemist, but I've been over the theory and market fairly thoroughly for work customers, but no need to believe me: I've cited references here before.I don't think you understand the workings of Li batteries.
https://www.physicsforums.com/showpost.php?p=2526716&postcount=10
https://www.physicsforums.com/showpost.php?p=2525412&postcount=9The majority of Li batteries that are suitable for EVs can not be charged or discharged below 0'C without some form of degradation.
Temporary degradation in capacity. A much more accurate statement than saying they "don't work".
If you knew this, and that GE is buying GM Volts, then what is the point of your statement #3 "Li powered EV's still don't work in cold weather. Are the GE employees that work in the sourthern part of the US only going to be allowed to drive EV's?"The Volt has an ICE which can both power the car and heat the batteries in sub zero climates. This means that the car can still operate without the use of its Li batteries in cold temperatures. Your regular EV can't. Thats why the Nissan Leaf isn't being sold in the colder regions of the US.
Again, reference? The forum guidelines require you to support statements of fact with a reference. (That 2002 link is irrelevant). If you have questions instead, ask them.My original comment stated "about 3 years" as in give or take 6 months or if you prefer, 3.5 years. Some of the newer batteries can probably last over 3 years but 4 is pushing it. [...]
