Young's double slit experiment green laser
The discussion focuses on calculating the total width of 11 green dots formed by a green laser (wavelength = 532 nm) passing through two slits with a separation of 127 μm, projected onto a screen 1.25 m away. The angle θ was calculated using the equation sinθ = mλ/d, resulting in θ = 1.2 degrees. The distance from the central maximum (m = 0) to the fifth order maximum (m = 5) was determined to be 2.61 cm. Consequently, the total width of the 11 dots is 5.24 cm.
  • Understanding of Young's double slit experiment
  • Familiarity with the equations mλ = dsinθ and tanθ = Y/L
  • Basic trigonometry for angle calculations
  • Knowledge of wavelength and slit separation units (nm and μm)
  • Explore the implications of varying slit separations on interference patterns
  • Learn about the impact of different wavelengths on diffraction and interference
  • Investigate advanced applications of Young's double slit experiment in quantum mechanics
  • Study the effects of screen distance on the visibility of interference patterns
Students studying physics, particularly those focusing on wave optics, as well as educators and anyone interested in experimental physics and interference phenomena.
Sullo
If a green laser is (wavelength = 532nm) sent through two slits with a separation of 127 um, how wide (in total) would the 11 green dots formed be if they were projected onto a screen 1.25m away from the slits?
Refer to this diagram sorry for bad quality: https://imgur.com/a/ACcJYJd
mλ=dsinθ
tanθ = Y/L
First find θ
sinθ = mλ/d
sinθ = [(5)(5.32x10^-9)] / 1.27x10^-6
sinθ = 2.09x10^-2
θ = 1.2 degrees
second, find distance from m = 0 to m = 5 (Y)
tanθ = Y/L
Y = Ltanθ
Y = 1.25tan(1.2)
Y = 2.61x10^-2m
So therefore, the total distance of the 11 dots will be twice the distance between M=0 and M=5
Total width of 11 dots = (2.61x10^-2) x 2 = 5.24x10^-2m
mλ=dsinθ
tanθ = Y/L
First find θ
sinθ = mλ/d
sinθ = 2.09x10^-2
θ = 1.2 degrees
tanθ = Y/L
Y = Ltanθ
Y = 1.25tan(1.2)
Y = 2.61x10^-2m
532 nm is 532x10-9m.
And what is the slit separation? 127 μm or 1.27 μm?
127um
11K
