Where Did the Young's Double Slit Experiment Calculation Go Wrong?
The forum discussion centers on the calculation errors in the Young's Double Slit Experiment, specifically regarding the relationship between slit width and amplitude. The user initially calculated the intensity ratios incorrectly, concluding that i(min)/i(max) = 15/17, which was not an option. After further analysis, they corrected their approach, determining that the correct intensity ratio is 3/5 based on the energy distribution from slits of different widths. The final conclusion emphasizes that the amplitude is not directly proportional to the slit width, leading to a more accurate understanding of the interference pattern.
  • Understanding of wave interference principles
  • Familiarity with amplitude and intensity relationships in wave physics
  • Knowledge of the Young's Double Slit Experiment
  • Basic mathematical skills for ratio calculations
  • Study the mathematical derivation of intensity ratios in wave interference
  • Learn about the principles of wave amplitude and its relation to energy
  • Explore variations of the Young's Double Slit Experiment with different slit configurations
  • Investigate the implications of amplitude addition in wave physics
Students of physics, educators teaching wave mechanics, and anyone interested in the principles of light interference and energy distribution in wave phenomena.
tanaygupta2000
The two slits in a Young’s double-slit experiment are of unequal width, one being four
time wider than the other. If i(max) and i(min) denote the intensities at a neighbouring
maximum and a minimum, then the ratio i(min)/i(max) is: (a)1/9 (b)1/4 (c)3/5 (d)0 ?
Intensity, i ∝ (amplitude)^2
Maximum i = i1 + i2
Minimum i = i1 -iI2
Since slit-2 = 4 × (slit-1)
Hence amplitude, a2 = 4a1
which gives i2 = 16×i1
So i(max) = i2 + i1 = 16i1 + i1 = 17i1
& i(min) = i2 - i1 = 16i1 - i1 = 15i1
=> i(min) /i(max) = 15/17
but there's no such option.
Kindly help me to figure out where am I doing error.
How much more energy is getting through the wider slit?
Energy, E ∝ (amplitude)^2
So, E2 = 16E1
So, E2 = 16E1
Does it seem reasonable that 16 times the energy gets through just because the slit is four times the width?
I think, because if a2 = 4a1 (which I doubt) and since Energy ∝ Intensity ∝ (amplitude)^2
I see no reason why the amplitude should be proportional to the width of the slit.
Suppose I have slit width W, then split it into two slits width W/2. How much of the original energy would go through each?
Yes I think the energy will be halved.
So, I guess the amplitude becomes a/√2 from each ?
Okay, I think I got the answer.
i(max) = i2 + i1 = 4i + i = 5i
i(min) = i2 - i1 = 4i - i = 3i
Hence i(min)/i(max) = 3i/5i = 3/5
which is option-(c)
Thank You so much for your help !
Right, so back to the given problem. What energy goes
which is option-(c)
No, it's not that simple.
Where the beams from the two slits overlap, the amplitudes add. That is why dark bands appear, positive amplitude plus negative amplitude.
I think the question intends you to argue like this:
- energies from the slits are in the ratio 4:1
- so amplitudes are in the ratio 2:1
- so where they fully reinforce the amplitude reaches 3, and where they maximally cancel the sum is only 1
- this gives an intensity ratio 9:1
I am not entirely unconvinced, though.
11K
