Young's Modulus and Interatomic Bond Length PLEASE HELP
The discussion revolves around calculating Young's modulus for a titanium alloy based on experimental measurements of a hanging wire's stretch under a load. The problem involves understanding the relationship between macroscopic properties like Young's modulus and microscopic properties such as interatomic bond stiffness.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the formula for Young's modulus and how to apply it using given measurements. There are questions about deriving force and cross-sectional area from the provided data. Some participants express uncertainty about the calculations and the relationships between variables.
Participants are actively engaging with the problem, attempting calculations and questioning each other's reasoning. Some guidance has been offered regarding the correct approach to finding the cross-sectional area and force, but there is no explicit consensus on the correct values or final calculations yet.
There are constraints regarding the units used in calculations, and participants are navigating through potential misunderstandings about the relationships between the variables involved in the problem.
luckyg14
A hanging wire made of an alloy of titanium with diameter 0.14 cm is initially 2.9 m long. When a 97 kg mass is hung from it, the wire stretches an amount 1.49 cm. A mole of titanium has a mass of 48 grams, and its density is 4.54 g/cm3.
Based on these experimental measurements, what is Young's modulus for this alloy of titanium?
Y = CANNOT FIGURE OUT
As you've done before, from the mass of one mole and the density you can find the length of the interatomic bond (diameter of one atom). This is 2.60 10-10 m for titanium. As shown in the textbook, the micro quantity ks,i (the stiffness of one interatomic bond) can be related to the macro property Y:
ks,i = CANNOT FIGURE OUT
Pls quote the equations you are aware of that relate to the definition of Young's modulus and (from your textbook) the relationship between interatomic bond stiffness and the modulus.
young's modulus is stress/ strain which is (F*Lo)/(Ao*delta_L) I do not know how to get the numbers and I don't understand how they relate to interatomic stiffness
okay so i know that Lo= 2.9m and delta_L= 0.0149m but I'm not sure how to get F and Ao
You're given the wire diameter, so what do you think the cross-sectional area will be?
What force will be exerted by a suspended 97kg mass?
Ao= 0.9079
I know force= m*a and I know that m is 97 but i don't know a
luckyg14 said:
Ao= 0.9079
What units? But I don't think that's right whatever units you chose. Pls show how you calculated it.
What does it mean to say something is hanging? What is the nature of the force that makes the wire stretch?
To find Ao i converted cm to m and then divided it by 2 to get the radius then used the area of a circle formula
and the force would be gravity
Correct procedure, but the answer was way off. Please post all that working.
Yes, so what force will the 97kg mass exert?
So i redid it and got Ao= .01539
and the force should be -950.6
it didn't work with those numbers idk what to do anymore but thank you
That's in sq cm, right?
Newtons. Always state the units.
So, plug those numbers in, be careful with the units, and post your working.
no its in meters because its supposed to be in meters.
i got 12021839.34 N/m and it was wrong
N/m^2
Then you calculated it wrongly. The diameter is 0.14cm, not 0.14m.
i converted it to meters because everything we do is always in meters
ok i redid my calculations again and got -264308724.8 N/m^2
would -264308724.8 be correct or should it be positive
It should be positive. If you are consistent, ΔL has the same sign as the force, which you've taken to be negative.
But I don't think that number is right yet. Radius = 0.07 cm, so area ≈ 0.015 sq cm = 1.5E-6 sq m. L = 2.9 m.; F = 97g ≈ 950N; ΔL ≈ 1.5 cm = 1.5E-2m.
950*2.9/(1.5E-6 * 1.5E-2) ≈ 1.2E11. That's roughly 500 times your number.
9K
  • · Replies 19 ·
21K
10K
