How Does Young's Modulus Relate to Spring Constants in Motion Equations?
The discussion focuses on deriving the equation of motion for a particle connected to two springs using Young's modulus and Hooke's Law. The particle's displacement from point A towards point B is analyzed, with the springs initially in a stretched state due to their natural lengths. There is confusion regarding the application of Young's modulus and its relationship with spring constants, particularly concerning the dimensions of the modulus and its representation in the equations. The participants express uncertainty about how to integrate these concepts into the motion equation, especially regarding the role of area and the nature of the forces involved. Ultimately, the problem emphasizes the need to clarify the definitions and relationships between the modulus of elasticity and spring constants in the context of the motion equation.
patrickmoloney
A particle mass m moves in a straight line on a smooth horizontal table, and is connected to two points A and B by light elastic springs of natural lengths 2l_{o} and 3l_{o}, respectively, and modulus of elasticity λ. The points A and B are a distance 6l_{o} apart. Show that the equation of motion can be written as m \ddot{x} = \frac{\lambda}{6l_{o}}(12l_{o}-5x)
where x is the displacement of the particle from A measures positive towards B
F = kx
\lambda = \frac{x}{l_{o}}
\frac{F}{A} = \lambda \frac{x}{l_{o}}
I'm not sure what to do here. I understand what the question is asking but I'm not sure how to go about it. It's asking for the equation of motion so does that mean I have to relate Hooke's Law with Young's modulus? The problem I'm having is that the equation that I was trying to solve the problem with has area in it. But we are talking about springs. So that's what makes me think I need to find a relationship between spring constant and modulus equation. The (12l_{o}-5x) part, is that from F= k(x - x_{o})
I've tried to relate hooke's law using this formula I read online k = \frac{\lambda A}{l}
if you could point me in the right direction I'd be very grateful.
A picture would be helpful. If I understand the problem, points A and B are 6L apart. Spring "A" = 2L and spring "B" = 3L, so before the problem even begins, the springs must be in an initially stretched state 2L + 3L + Xo = 6L correct? or X (initial combined stretch of the springs = L)?
Looking at the thing to be proved, λ has the dimension of force. So it is not what is properly called modulus of elasticity. Rather, it is the modulus multiplied by the cross sectional area.
The "relevant equations" seem to imply Lambda is 2 different things? The second equation implies lambda is some form of strain, the 3rd equation implies lambda is the modulus of elasticity (Young's Modulus). The solution equation implies the motion is undamped free vibration --> no velocity or damping terms are included.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 23 ·
