YouTube Classics, Part Deux
- Thread starter lisab
- Start date
- Tags
- Youtube
830 replies · 104K views · last reply
- Air holes turn silicon wafers into flat ultraviolet focusing mirrors for compact optics
- Quantum gas microscope reveals individual atoms in first tunable three-component Hubbard system
- Scientists achieve record-breaking low temperature on China's space station, paving the way for new physics experiments
etotheipi
skyshrimp
- 39
- 122
etotheipi
what the f*ck has happened to my youtube recommendations
etotheipi
Jarvis323
- 1,247
- 988
Staff Emeritus
- 2,666
Staff Emeritus
- 2,666
I think I know the key to how it works. Anyone want to explain?
Homework Helper
- 13,438
- 8,113
Check out this thread in the Classical Physics sub-forum.Ivan Seeking said:I think I know the key to how it works. Anyone want to explain?
https://www.physicsforums.com/threads/ddwfttw-looking-for-the-least-confusing-explanation.896869/
I recommend reading the entire thing before attempting to add anything. Pretty much everything that could be said has already been said.
DaveC426913
2025 Award
- 24,733
- 9,161
The TL;DR version:Ivan Seeking said:I think I know the key to how it works. Anyone want to explain?
Three key facts:
- A sailboat can sail downwind off wind faster than the wind. (i.e. on a broad reach, it is possible for a sailboat to beat a drifting balloon. (07m30s)
- This effect can be utilized, although not on the way one might expect. (8m05s)
- The propeller is not driving the wheels. (This is the key key.) In fact, the wheels are driving the propeller. The propeller is what is pushing the vehicle forward - which is why it can exceed the wind speed. (10m58s).
Staff Emeritus
- 2,666
Let me state that another way: Calculate the maximum speed based on the initial wind speed V.DaveC426913 said:The TL;DR version:
Three key facts:
DaveC426913
2025 Award
- 24,733
- 9,161
I don't know how I would do that, but wouldn't you need to know how the gadget works (to know what forces are involved) to figure that out?Ivan Seeking said:Let me state that another way: Calculate the maximum speed based on the initial wind speed V.
Anyway, they managed to achieve a much higher v than I assumed. They managed to reach 2.8 times wind speed!
Staff Emeritus
- 2,666
You simply assign variables for air friction, road friction, blade size, design, and pitch, etc... If you really understand how it works, you can set up the problem. The actual numbers are irrelevant.DaveC426913 said:I don't know how I would do that, but wouldn't you need to know how the gadget works (to know what forces are involved) to figure that out?
The key is to determine precisely how energy is added to the system.
Homework Helper
- 13,438
- 8,113
If you have thrust to drag ratio for the airfoil, that should be enough.Ivan Seeking said:You simply assign variables for air friction, road friction, blade size, design, and pitch, etc... If you really understand how it works, you can set up the problem. The actual numbers are irrelevant.
Friction with the ground is irrelevant since one can make the craft as massive as is required to obtain the requisite traction. Friction with the air is irrelevant since one can make the prop as large as required (ignoring materials issues). Blade size, design and pitch are irrelevant if one can distill the performance down to thrust versus drag.
Staff Emeritus
- 2,666
jbriggs444 said:If you have thrust to drag ratio for the airfoil, that should be enough.
I have seen two pages of arm waving over this and not one equation.
Is this a bar or Physics Forums? Perhaps I took a wrong turn. ;)
Oh yes, and they have to adjust pitch.
Homework Helper
- 13,438
- 8,113
This is General Discussion. In particular, "YouTube Classics, Part Deux".Ivan Seeking said:Is this a bar or Physics Forums? Perhaps I took a wrong turn. ;)
Staff Emeritus
- 2,666
And a thread was linked. ;)jbriggs444 said:This is General Discussion. In particular, "YouTube Classics, Part Deux".
Homework Helper
- 3,448
- 3,795
Here's an update on the faster than wind, downwind vehicle. For technical discussions, there is already a thread in place for this here: https://www.physicsforums.com/threa...the-least-confusing-explanation.896869/page-3
Staff Emeritus
- 2,666
nsaspook said:
collinsmark said:Here's an update on the faster than wind, downwind vehicle. For technical discussions, there is already a thread in place for this here: https://www.physicsforums.com/threa...the-least-confusing-explanation.896869/page-3
Fantastic! He really nails it intuitively in the demo with the wheels and board at the end. And in the first video linked above, she nails it down as to WHAT "gear ratio" is in play.
Staff Emeritus
- 2,666
It was cool to find this original version of David Bowie singing Space Oddity.
