Zag Solenoid: Using Magnetic Field Force Formula
  • Context: Undergrad
  • Thread starter Thread starter Ziggey
    Building Solenoid
6 replies · 3K views
Ziggey
Hello so I just want to make sure I Am doing this correctly.
also I know there is a magnetic field force formula. That is F= qv (dot) B
How would I go about using that formula with the magnetic field I created from the solenoid in the picture?
Thanks for any help!
Zig
Ok I'm using the equation B= unI
n=N/L
u=k(4*pie*10^-7)
k=200
Once I plug in the numbers I get n= 18/.504=35.7142, u= 2.513*10^-4.
So if I have 10 amps then my final number should be .0897 B. Did I do that correct?
For the values you have assumed, the calculations seem correct. About the magnetic field force formula, you are referring to Lorentz force formula:##F=q (\vec{v}\times\vec{B})##
Ok well what I don't understand about that equation is the velocity part. I have been trying to do some reading on it, but I don't understand it. Is the velocity for the speed of the electron or something else?
Ok I will try and get it then show my work to make sure I'm doing it correctly. Thank you for the help! Zig
