Which members in the truss are zero force?
The discussion focuses on identifying zero-force members in a truss structure, specifically at Joint C, which has four members connected. It is established that when a joint has four members, no definitive rule exists to identify zero-force members. Additionally, Joints E and K are confirmed to be loaded due to reaction forces. The participants emphasize the need for equilibrium calculations to analyze the forces acting on the members.
  • Understanding of truss structures and their components
  • Knowledge of static equilibrium principles
  • Familiarity with joint analysis in structural engineering
  • Basic concepts of reaction forces in mechanics
  • Study the method of joints in truss analysis
  • Learn about equilibrium equations for trusses
  • Explore the concept of zero-force members in truss systems
  • Review reaction force calculations in structural mechanics
This discussion is beneficial for civil engineering students, structural engineers, and anyone preparing for exams related to truss analysis and mechanics of materials.
DiamondV
Okay, I need help quick, exam in few hours, I won't be able to reply to this later.
http://puu.sh/lQeXl/42907b0a12.jpg
In my lectures notes this is given. In the example shown with it, the one on the right in particular. Look at Joint C, it is unloaded, it also has to members connected to CG and CH both of which are non-collinear, but neither is zero force? I know technically there are 4 members connected to Joint C but I have no rule for 4 members so I just thought maybe we just ignore the other two(sounds weird) No other info about zero force members was given.
Also one more thing, Joints E and K, they are loaded due to the reaction forces correct?
N/A
N/A[/B]
That simply means you can not identify a zero-force member there.
Correct
Good luck with your test ! :smile:
Correct
So I would have to do out the equilibrium calculations to find if there are any zero force members connected to a joint with 4 members.
Don't think that will help: then you still have 4 members (and a force). But I'm not an expert, so not sure.
