Zero-point energy from Schroedinger equation using Ritz variaton principle
The discussion revolves around calculating the zero-point energy of the hydrogen atom using the Ritz variational principle and the Schrödinger equation in spherical coordinates. Participants are exploring the application of the variational method and the implications of their mathematical manipulations.
  • Participants discuss the application of the Hamiltonian to the trial wave function and the need to clarify the constants involved in the energy estimate. There are questions about the integration process and the correctness of the integral measures used. Some participants suggest reviewing the form of the angular momentum operator in spherical coordinates to simplify the problem.
The discussion is active, with participants providing feedback on each other's approaches and questioning specific mathematical steps. Some guidance has been offered regarding the correct form of the angular momentum operator and the integration limits in spherical coordinates. Multiple interpretations of the problem setup are being explored, indicating a productive exchange of ideas.
Participants are addressing potential misconceptions related to spherical coordinates and the proper treatment of wave functions in this context. There is an emphasis on ensuring that the mathematical expressions accurately reflect the physical situation being modeled.
Juqon
Calculate the zero-point energy of the hydrogen atom using the Ritz variaton principle and the approach \psi_{\alpha}.
Hint: The stationary Schroedinger equation in spherical coordinates is ...
\left\{ -\frac{\hbar^{2}}{2\mu}\left[\frac{\partial^{2}}{\partial r^{2}}+\frac{2}{r}\frac{\partial}{\partial r}\right]+\frac{\hat{\vec{L}}^{2}}{2\mu r^{2}}+V(r)\right\} \psi=E\psi<br /> <br /> \psi_{\alpha}(\vec{r})=C\exp\left\{ -\alpha r\right\} ;C&gt;0;\alpha&gt;0; C,\alpha=const. <br /> <br /> \int_{0}^{\infty}dr\cdot r\cdot\exp\left\{ -2\alpha r\right\} =\frac{1}{4}\alpha^{2}<br /> <br /> \int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} =\frac{1}{4}\alpha^{3}
<br /> \left\{ -\frac{\hbar^{2}}{2\mu}\left[\frac{\partial^{2}}{\partial r^{2}}+\frac{2}{r}\frac{\partial}{\partial r}\right]+\frac{\hat{\vec{L}}^{2}}{2\mu r^{2}}+V(r)\right\} \psi=E\psi<br /> <br /> \Leftrightarrow \left\{ -\frac{ \hbar^{2} }{2\mu} \left [\frac{\partial^{2}} {\partial r^{2}}+ \frac{2}{r} \frac {\partial} {\partial r} \right]+ \frac {\left(\hbar^{2} l(l+1) \right)^{2}} {2\mu r^{2}}+\frac{1} {4\pi\epsilon_{0} } \frac{qQ}{r} \cdot C \cdot \exp -\alpha r \right\} \cdot C\cdot\exp\left\{ -\alpha r\right\} = E \cdot C\cdot\exp\left\{ -\alpha r\right\}<br /> <br /> \Leftrightarrow \left\{ -\frac{\hbar^{2}}{2\mu}\left [\alpha^{2}-\frac{2}{r}\alpha\right] +\frac{\hbar^{4}l^{2} (l^{2}+2l+1)}{2\mu r^{2}} +\frac{1}{4\pi\epsilon_{0}}\frac{qQ} {r}\right\} \cdot C\cdot\exp\left\{ -\alpha r\right\} = E \cdot C\cdot\ exp\left\{ -\alpha r\right\}<br /> <br /> \Leftrightarrow E=\left\{ -\frac{\hbar^{2}}{2\mu}\left[\alpha^{2}-\frac{2}{r}\alpha \right]+\frac{\hbar^{4}l^{2}(l^{2}+2l+1)}{2\mu r^{2}}+\frac{1}{4\pi\epsilon_{0}} \frac{qQ}{r}\right\}
Where do I need to integrate at all?
Your Schrödinger equation seems to be missing a plus or minus sign.
All you've done is apply the Hamiltonian to the trial function. Your estimate for E is supposed to be a constant. You still have r's and l's in it as well as the parameter alpha. You need to review what you're supposed to do to solve for the estimate of the ground state energy. This example might help you see what the general procedure is:
http://quantummechanics.ucsd.edu/ph130a/130_notes/node378.html#example:hopoly
Ok, I will correct the sign, sorry.
The example was very helpful, thanks. Did I use the integral measure correctly? And is the result really that complicated?
<br /> E_{0}=\frac{&lt;\psi|\hat{H}|\psi&gt;}{&lt;\psi|\psi&gt;}= \frac{\int_{-\infty}^{\infty} dr\cdot r^{2}\cdot\psi^{*}\left\{ -\frac{\hbar^{2}}{2\mu}\left[\alpha^{2}-\frac{2}{r}\alpha\right]\psi+\frac{\hbar^{4}l^{2}(l^{2}+2l+1)}{2\mu r^{2}}\psi+\frac{1}{4\pi \epsilon_{0} } \frac{qQ}{r}\psi\right\} }{\int_{-\infty}^{\infty}dr\psi^{*}\psi}
<br /> <br /> <br /> =\frac{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} \left\{ \frac{ \hbar^{2}}{2\mu}\frac{2}{r}\alpha+\frac{ \hbar^{4}l^{2}(l^{2}+2l+1)}{2\mu r^{2}}-\frac{ \hbar^{2}}{2\mu}\alpha^{2}+\frac{1}{4\pi \epsilon_{0} } \frac{qQ}{r}\right\} }{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} }
<br /> <br /> <br /> =\frac{2\int_{0}^{\infty}dr\cdot\exp\left\{ -2\alpha r\right\} \left\{ \frac{\hbar^{2}}{2\mu}2r\alpha+r^{2}\frac{\hbar^{4}l^{2}(l^{2}+2l+1)}{2\mu}-r^{2}\frac{\hbar^{2}}{2\mu}\alpha^{2}+\frac{r}{4 \pi \epsilon_{0} } \frac{qQ}{1}\right\} }{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} }
<br /> <br /> <br /> =\frac{2\int dr\cdot\exp\left\{ -2\alpha r\right\} \cdot r\left\{ \frac{\hbar^{2}}{2\mu}2\alpha+\frac{1}{4\pi \epsilon_{0} } \frac{qQ}{1}\right\} +2\int dr\cdot\exp\left\{ -2\alpha r\right\} \cdot r^{2}\cdot\left(\frac{\hbar^{4}l^{2}(l^{2}+2l+1)}{2\mu}-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} }
<br /> <br /> <br /> =\frac{2\cdot\frac{1}{4}\alpha^{2}\left\{ \frac{\hbar^{2}}{2\mu}2\alpha+\frac{1}{4\pi \epsilon_{0} } \frac{qQ}{1}\right\} +2\frac{1}{4}\alpha^{3}\cdot\left(\frac{\hbar^{4}l^{2}(l^{2}+2l+1)}{2\mu}-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{2\frac{1}{4}\alpha^{3}}
<br /> <br /> <br /> =\frac{\frac{1}{2}\alpha^{2}\left\{ \frac{\hbar^{2}}{2\mu}2\alpha+\frac{1}{4\pi \epsilon_{0} } \frac{qQ}{1}\right\} +\frac{1}{2}\alpha^{3}\cdot\left(\frac{\hbar^{4}l^{2}(l^{2}+2l+1)}{2\mu}-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{\frac{1}{2}\alpha^{3}}
<br /> <br /> <br /> E_{0}=\frac{1}{4\pi \epsilon_{0} } \frac{qQ}{\alpha}+\frac{ \hbar^{2}}{2\mu}2+\frac{\hbar^{4}l^{2}(l^{2}+2l+1)-\hbar^{2}\alpha^{2}}{2\mu}
<br /> <br /> <br /> \frac{\partial E_{0}}{\partial\alpha}=- \frac{1}{4\pi \epsilon_{0} } \frac{qQ}{\alpha^{2}}+\frac{\hbar^{4}l^{2}(l^{2}+2l+1)-\hbar^{2}\alpha}{\mu}=0\Leftrightarrow\frac{\hbar^{4}l^{2}(l^{2}+2l+1)-\hbar^{2}\alpha}{\mu}=\frac{1}{4\pi \epsilon_{0} } \frac{qQ}{\alpha^{2}}
<br /> <br /> <br /> \Leftrightarrow\alpha^{3}= \frac{qQ}{4\pi \epsilon_{0} } \frac{\mu}{\hbar^{4}l^{2}(l^{2}+2l+1)- \hbar^{2}}\Leftrightarrow\alpha= \sqrt[3]{\frac{qQ}{4\pi \epsilon_{0} } \frac{\mu}{\hbar^{2}\left(l^{2}(l^{2}+2l+1)-1\right)}}
<br /> <br /> <br /> E_{0}=\frac{1}{4\pi \epsilon_{0} } \frac{qQ}{\sqrt[3]{\frac{qQ}{4\pi \epsilon_{0} } \frac{\mu}{\hbar^{2}\left(l^{2}(l^{2}+2l+1)-1\right)}}}+ \frac{\hbar^{2}}{2\mu}2+ \frac{\hbar^{4}l^{2}(l^{2}+2l+1) - \hbar^{2}\left(\frac{qQ}{4\pi \epsilon_{0} } \frac{\mu}{\hbar^{2}\left(l^{2}(l^{2}+2l+1)-1\right)}\right)^{\frac{2}{3}}}{2\mu}
It's a bit simpler than what you have. First, find out what the L2 operator looks like in spherical coordinates. That'll simplify things quite a bit.
You used \hat{L}^2\psi = \hbar^2[l(l+1)]^2\psi, which is incorrect. If you have an eigenfunction \psi_{nlm}, then \hat{L^2}\psi_{nlm} = \hbar^2 l(l+1) \psi_{nlm}. The factor l(l+1) isn't squared.
Where did those factors of 2 in front of each integral come from?
Wikipedia says L^2 = -\hbar^2 \left(\frac{1}{\sin\theta}\frac{\partial}{\partial \theta}\left( \sin\theta \frac{\partial}{\partial \theta}\right) + \frac{1}{\sin^2\theta}\frac{\partial^2}{\partial \phi^2}\right). But that would be more complicated, because I don't see it go away by a derivation. \psi is still dependent on the angles. Besides, there is an r² too much in front of \frac{\hbar^{4}l^{2}(l^{2}+2l+1)}{2\mu r^{2}} in my solution.
An integral from -infinity to +infinity is two times the same integral from 0 to infinity.
You seem to have some misconceptions related to spherical coordinates. You need to get those straightened out first, so you should go back and review the basics of spherical coordinates. Note that the vector \vec{r} and the coordinate r are not the same thing, so in the equations you find in your textbook, you need to understand which one is being referred to.
Say you have a generic wave function \psi. In Cartesian coordinates, the quantity \langle \psi \vert \psi \rangle would be given by\langle \psi \vert \psi \rangle = \int_{-\infty}^\infty \int_{-\infty}^\infty \int_{-\infty}^\infty \psi^*(x,y,z)\psi(x,y,z)\,dx\,dy\,dzHow would you express this quantity using spherical coordinates?
I'd say that is in spherical coordinates:
\langle \psi \vert \psi \rangle = \int_{-\infty}^\infty \int_{-\infty}^\infty \int_{-\infty}^\infty r²\cdot sin² (\theta) \psi^*(r, \theta,\phi)\psi(r,\theta,\phi)\ ,dr\,d \theta\,d\phi.
I understand of course that \vec{r}=(r cos \theta cos \phi, r cos \theta sin ..., cos) or something like that. Still don't see the connection.
Close, but you need to understand what values the coordinates can take on in each system. In Cartesian coordinate, you have to let x, y, and z each run from -∞ to +∞ to cover all of space. What about in spherical coordinates? Remember you don't want to cover a point multiple times. There should be only one combination of r, θ, and φ for each point in space.
\langle \psi \vert \psi \rangle = \int_{0}^\infty \int_{0}^\pi \int_{0}^{2\pi} r²\cdot sin² (\theta) \psi^*(r, \theta,\phi) \psi(r,\theta,\phi)\ ,dr\,d \theta\, d\phi
That's correct except sin θ shouldn't be squared.
So now back to the problem. You have \psi = C e^{-\alpha r}, so\langle \psi \vert \psi \rangle = \int_0^\infty \int_0^\pi \int_0^{2\pi} e^{-2\alpha r}r^2\sin \theta \,dr\,d\theta\,d\phiWhat do you get when you evaluate this integral?
\langle \psi \vert \psi \rangle = \int_0^\infty \int_0^\pi \int_0^{2\pi} e^{-2\alpha r}r^2\sin \theta \,dr\,d\theta\,d\phi=\frac{1}{4}\alpha^{3} \cdot 2\pi²
And with L^2 = -\hbar^2 \left(\frac{1}{\sin\theta}\frac{\partial}{\partial \theta}\left( \sin\theta \frac{\partial}{\partial \theta}\right) + \frac{1}{\sin^2\theta}\frac{\partial^2}{\partial \phi^2}\right) the whole L term goes away?
That's not correct. Try again.
Yes. Can you explain why?
\langle \psi \vert \psi \rangle = \int_0^\infty \int_0^\pi \int_0^{2\pi} e^{-2\alpha r}r^2\sin \theta \,dr\,d\theta\,d\phi=\frac{1}{4}\alpha^{3} \cdot 2\pi \cdot\left[-cos\right]^\pi _0 = \frac{1}{4}\alpha^{3} \cdot 2\pi \cdot\left[-(-1) - (-(1))\right]=\frac{1}{4}\alpha^{3} \cdot 4\pi =\alpha^{3}\pi
It goes away because it is differentiated with respect to \theta and \varphi, but these are not in the result any more, is a constant with respect to the angles and thus 0.
Excellent! Now onto the numerator...
Thanks, now here is my newest problem.
[EDIT: I think I found it.]E_{0}=\frac{&lt;\psi|\hat{H}|\psi&gt;}{&lt;\psi|\psi&gt;}= \frac{\int_{-\infty}^{\infty}dr\cdot r^{2}\cdot\psi^{*}\left\{ -\frac{\hbar^{2}}{2\mu}\left[\alpha^{2}-\frac{2}{r}\alpha\right]\psi+\frac{1}{4\pi\epsilon_{0}} \frac{qQ}{r}\psi\right\} }{\int_{-\infty}^{\infty}dr\psi^{*}\psi}
<br /> <br /> =\frac{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} \left\{ \frac{\hbar^{2}}{2\mu}\frac{2}{r}\alpha-\frac{\hbar^{2}}{2\mu}\alpha^{2}+\frac{1}{4 \pi \epsilon_{0}}\frac{qQ}{r}\right\} }{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} }<br />
=\frac{2\int_{0}^{\infty}dr\cdot\exp\left\{ -2\alpha r\right\} \left\{ \frac{\hbar^{2}}{2\mu}2r\alpha-r^{2}\frac{\hbar^{2}}{2\mu}\alpha^{2}+\frac{r}{4 \pi \epsilon_{0}}\frac{qQ}{1}\right\} }{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} }<br /> =\frac{2\int dr\cdot\exp\left\{ -2\alpha r\right\} \cdot r\left\{ \frac{\hbar^{2}}{2\mu}2\alpha+\frac{1}{4 \pi \epsilon_{0}}\frac{qQ}{1}\right\} +2\int dr\cdot\exp\left\{ -2\alpha r\right\} \cdot r^{2}\cdot\left(-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} }<br /> <br />
<br /> =\frac{2\cdot\frac{1}{4}\alpha^{2}\left\{ \frac{\hbar^{2}}{2\mu}2\alpha+\frac{1}{4 \pi \epsilon_{0}}\frac{qQ}{1}\right\} +2\frac{1}{4}\alpha^{3}\cdot\left(-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{2\frac{1}{4}\alpha^{3}}
=\frac{\frac{1}{2}\alpha^{2}\left\{ \frac{\hbar^{2}}{2\mu}2\alpha+\frac{1}{4 \pi \epsilon_{0}}\frac{qQ}{1}\right\} +\frac{1}{2}\alpha^{3}\cdot\left(-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{\frac{1}{2}\alpha^{3}}<br /> <br />
<br /> <br /> E_{0}=\frac{1}{4 \pi \epsilon_{0}}\frac{qQ}{\alpha}+\frac{\hbar^{2}}{ \mu}<br /> <br />
<br /> <br /> \frac{\partial E_{0}}{\partial\alpha}=-\frac{1}{4 \pi \epsilon_{0}}\frac{qQ}{\alpha^{2}}=0
You don't see a disconnect between what you wrote in post 13 and what you wrote in post 15?
This is my newest version. I think I showed in #13 what the result of the integral ist, but now that differentiations make it 0 I deleted the whole L term.
<br /> E_{0}= \frac{&lt;\psi|\hat{H}|\psi&gt;}{&lt;\psi|\psi&gt;}=\frac{\int_{-\infty}^{\infty}dr\cdot r^{2}\cdot\psi^{*}\left\{ -\frac{\hbar^{2}}{2\mu}\left[\alpha^{2}-\frac{2}{r}\alpha\right]\psi-\frac{e^{2}}{r}\psi\right\} }{\int_{-\infty}^{\infty}dr\psi^{*}\psi}<br />
<br /> <br /> <br /> =\frac{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} \left\{ \frac{\hbar^{2}}{2\mu}\frac{2}{r}\alpha-\frac{\hbar^{2}}{2\mu}\alpha^{2}-\frac{e^{2}}{r}\right\} }{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} }<br />
<br /> <br /> <br /> =\frac{2\int_{0}^{\infty}dr\cdot\exp\left\{ -2\alpha r\right\} \left\{ \frac{\hbar^{2}}{2\mu}2r\alpha-r^{2}\frac{\hbar^{2}}{2\mu}\alpha^{2}-e^{2}\right\} }{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} }<br />
<br /> <br /> <br /> =\frac{2\int dr\cdot\exp\left\{ -2\alpha r\right\} \cdot r\left\{ \frac{\hbar^{2}}{2\mu}2\alpha-e^{2}\right\} +2\int dr\cdot\exp\left\{ -2\alpha r\right\} \cdot r^{2}\cdot\left(-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{2\int_{0}^{\infty}dr\cdot r^{2}\cdot\exp\left\{ -2\alpha r\right\} }<br /> <br />
<br /> <br /> =\frac{2\cdot\frac{1}{4}\alpha^{2}\left\{ \frac{\hbar^{2}}{2\mu}2\alpha-e^{2}\right\} +2\frac{1}{4}\alpha^{3}\cdot\left(-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{2\frac{1}{4}\alpha^{3}}<br /> <br />
<br /> <br /> =\frac{\frac{1}{2}\alpha^{2}\left\{ \frac{\hbar^{2}}{2\mu}2\alpha-e^{2}\right\} +\frac{1}{2}\alpha^{3}\cdot\left(-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{\frac{1}{2}\alpha^{3}}<br /> <br />
<br /> <br /> E_{0}=-\frac{e^{2}}{\alpha}+\frac{\hbar^{2}}{\mu}-\frac{\hbar^{2}}{2\mu}\alpha^{2}<br />
<br /> <br /> <br /> \frac{\partial E_{0}}{\partial\alpha}=\frac{e^{2}}{\alpha^{2}}-\frac{\hbar^{2}}{\mu}\alpha=0\Leftrightarrow\frac{\hbar^{2}}{\mu}\alpha=\frac{e^{2}}{\alpha^{2}}<br /> <br />
<br /> <br /> \Leftrightarrow\alpha^{3}=e^{2}\cdot\frac{\mu}{ \hbar^{2}}\Leftrightarrow\alpha=\sqrt[3]{e^{2}\cdot\frac{\mu}{\hbar^{2}}}<br />
<br /> <br /> <br /> E_{0}=- \frac{e^{2}}{\sqrt[3]{e^{2}\cdot\frac{\mu}{\hbar^{2}}}} + \frac{\hbar^{2}}{\mu}-\frac{\hbar^{2}}{2\mu} \sqrt[3]{e^{2}\cdot\frac{\mu}{\hbar^{2}}}^{2}<br />
Look at the denominators in the very first line. How is that consistent with what you have in post #13?
Mh, I didn't change the other integrals.
<br /> <br /> E_{0}= \frac{&lt;\psi|\hat{H}|\psi&gt;}{&lt;\psi|\psi&gt;}=\frac{\int_{-\infty}^{\infty}d\vec{r}\psi^{*}\left\{ -\frac{\hbar^{2}}{2\mu}\left[\alpha^{2}-\frac{2}{r}\alpha\right]\psi-\frac{e^{2}}{r}\psi\right\} }{\int_{-\infty}^{\infty}d\vec{r}\psi^{*}\psi}
<br /> <br /> <br /> =\frac{\int_{-\infty}^{\infty}d\vec{r}\exp\left\{ -2\alpha r\right\} \left\{ \frac{\hbar^{2}}{2\mu}\frac{2}{r}\alpha-\frac{\hbar^{2}}{2\mu}\alpha^{2}-\frac{e^{2}}{r}\right\} }{\int_{-\infty}^{\infty}d\vec{r}\exp\left\{ -2\alpha r\right\} }
<br /> <br /> <br /> =\frac{\int_{0}^{\infty}dr \int_{0}^{\pi}d\theta\int_{0}^{2\pi}d\phi\cdot\sin\theta\cdot\exp\left\{ -2\alpha r\right\} \cdot r\left\{ \frac{\hbar^{2}}{2\mu}2\alpha-e^{2}\right\} +\int_{0}^{\infty}dr\int_{0}^{\pi}d\theta\int_{0}^{2\pi}d\phi\cdot\sin\theta\cdot\exp\left\{ -2\alpha r\right\} \cdot r^{2}\cdot\left(-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{\int_{0}^{\infty}dr\int_{0}^{\pi}d\theta\int_{0}^{2\pi}d \phi\cdot r^{2}\sin\theta\cdot\exp\left\{ -2\alpha r\right\} }
<br /> <br /> <br /> =\frac{\pi\alpha^{2}\left\{ \frac{\hbar^{2}}{\mu}\alpha-e^{2}\right\} +\pi\alpha^{3}\cdot\left(-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{\pi\alpha^{3}}
<br /> <br /> <br /> E_{0}=-\frac{e^{2}}{\alpha}+\frac{\hbar^{2}}{\mu}\left(1-\frac{\alpha^{2}}{2}\right)
<br /> <br /> <br /> \frac{ \partial E_{0}}{\partial\alpha}=\frac{e^{2}}{\alpha^{2}}-\frac{\hbar^{2}}{\mu}2\alpha=0 \Leftrightarrow\frac{\hbar^{2}}{\mu}2\alpha=\frac{e^{2}}{\alpha^{2}}
<br /> <br /> <br /> \Leftrightarrow \alpha^{3}=e^{2}\cdot\frac{\mu}{2\hbar^{2}} \Leftrightarrow\alpha=\sqrt[3]{e^{2}\cdot\frac{\mu}{2 \hbar^{2}}}
<br /> <br /> <br /> E_{0}=-\frac{e^{2}}{\sqrt[3]{e^{2}\cdot\frac{\mu}{2\hbar^{2}}}}+\frac{\hbar^{2}}{\mu2}\left(2-\sqrt[3]{e^{2}\cdot\frac{\mu}{2\hbar^{2}}}^{2}\right)
The integrals should be
\begin{align*}
\int_0^\infty r e^{-2\alpha r}\,dr = \frac{1}{4\alpha^2} &\\
\int_0^\infty r^2 e^{-2\alpha r}\,dr = \frac{1}{4\alpha^3} &
\end{align*}
With those corrections, it should work out.
You are right, the integrals were wrong, thank you. This is my calculation with the right ones:
E_{0}=\frac{\frac{\pi}{\alpha^{2}}\left\{ \frac{\hbar^{2}}{\mu}\alpha-e^{2}\right\} +\frac{\pi}{\alpha^{3}}\cdot\left(-\frac{\hbar^{2}}{2\mu}\alpha^{2}\right)}{\frac{\pi}{\alpha^{3}}}
E_{0}=\frac{\hbar^{2}}{\mu}\alpha^{2}\left(1-\frac{1}{2}\right)-e^{2}\alpha
E_{0}=\frac{\hbar^{2}}{2\mu}\alpha^{2}-e^{2}\alpha
\frac{\partial E_{0}}{\partial\alpha}=\frac{\hbar^{2}}{\mu}\alpha-e^{2}=0\Leftrightarrow\frac{\hbar^{2}}{\mu}\alpha=e^{2}
\Leftrightarrow\alpha=e^{2}\cdot\frac{\mu}{\hbar^{2}}
E_{0}=\frac{\hbar^{2}}{2\mu}\left(e^{2}\cdot\frac{\mu}{\hbar^{2}}\right)^{2}-e^{2}\left(e^{2}\cdot\frac{\mu}{\hbar^{2}}\right)
E_{0}=\frac{\hbar^{2}}{2\mu}e^{4}\cdot\frac{\mu^{2}}{\hbar^{4}}-e^{4}\cdot\frac{\mu}{\hbar^{2}}
=\left( \frac{\mu }{2 \hbar^{2} }- \frac{\mu}{\hbar^{2} }\right) \cdot e^{4} =\frac{\mu}{\hbar^{2}} \left( \frac{1}{2}-1\right) \cdot e^{4}=-\frac{\mu e^{4}} {2 \hbar^{2}}
  • · Replies 19 ·
  • · Replies 30 ·
