Finding X and Y with respect to third variable if having two sets of X and Y
  • Thread starter Thread starter kunju
    Sets Variable
The discussion revolves around determining Y values for given X values at a new temperature of 9.6 degrees, based on previous data at 5 and 7 degrees. The user has already created polynomial equations for the existing X and Y pairs in Excel but seeks guidance on how to extend this to the new temperature. Participants suggest finding curve fits for Y as a function of temperature and for X as a function of temperature, leading to two separate functions, Y(T) and X(T). Clarification is provided that the designations of X and Y may need to be reconsidered for accurate representation in the equations. The conversation emphasizes the importance of correctly identifying the independent variable for proper analysis.
kunju
My problem
At temperature 5 degrees the Y=1.00228594 for X=435 and Y=1.000986038 for X=449 and Y=0.999760292 for X=463
At temperature 7 degrees the Y=1.002094781 for X=435 and Y=1.00079709 for X=449 and Y=0.999573015 for X =463
For a new temperature of 9.6 degrees how to find the Y values for different X values
I find a polynomial eqn for the first set of X and Y values , then I find a polynomial eqn for the second set of X and Y values in excel. How can i find a polynomial for a different temp in excel
help me out
Thanks
Mathematics news on Phys.org
I am not sure I follow when you say you find a polynomial for the first set...
What's Y? What's X? Are they independent from each other? Is temperature the only independent variable?
I think all you need to do is find a curve fit for Y alone based on T, and then you find a curve fit for X based on T; then, you will have two curves, functions Y(T) and X(T).
So, just because you name Y Y and X X does not mean they should be your X,Y coordinates.
So, maybe you need to think of your Y as Y1 and your X as Y2 and your T as X and so you will have Y1(X) and Y2(X)
does this help?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
