What Temperatures Contribute to Air's Heat Capacity Due to Vibration?
glebovg
Air is mostly composed of diatomic nitrogen, N2. Assume that we can model the gas as an oscillator with an effective spring constant of 2.3 x 103 N/m and and effective oscillating mass of half the atomic mass. For what temperatures should vibration contribute to the heat capacity of air?
\omega=\sqrt{\frac{\kappa}{m}}
E=\hbar\omega
K=\frac{3}{2}k_{B}T
\omega=\sqrt{\frac{\kappa}{m}}=1.67\times10^{15} rad/s
E=\hbar\omega=1.76\times10^{-19} J
I am not sure what to do next.
Can anyone help?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
