Why Does Pi Appear in So Many Scientific Equations?
  • Thread starter Thread starter goldsax
    Pi
Pi appears in numerous scientific equations primarily due to its fundamental relationship with circles and spheres, making it essential in calculations involving rotational symmetry and densities. Its presence is also linked to mathematical functions like sine, cosine, and tangent, which are inherently tied to circular geometry. Additionally, pi emerges in complex numbers and exponential functions, reinforcing its significance across various fields of study. While no specific book may directly address pi's ubiquity, familiarity with scientific theories allows one to recognize the connections between pi and other physical constants. Understanding these relationships enhances comprehension of mathematical and physical concepts.
goldsax
we all know the PI crops up everywhere..
why for example would PI be found in the equation for the density parameter of the cosmological constant etc..
is there a book that can explain why PI rears its head up in all types os studies...
cheers
Astronomy news on Phys.org
Anything that involves any kind of cirlcle, sphere or ball is going to involve pi, it crops up in densities and the likes because it's convenient to work with densities of 'balls' (especially if they are rotationally symmetrical!).
It's just like hbar in quantum mechanics, c in relativity and boltzmans k in thermodynamics (assuming we're not working in specialised units where certain constants are set = 1)
No pi = not working with cirlces, spheres etc
No hbar = classical limit
No c = non relativistic limit
No k = working at absolute zero
edit;
In regards to books, none that I know of will explicitely point this out but once you get use to the theories you'll start to see links between these physical constants and where they come from.
@genericusrnme
Pi can also be the result of mathematics. Pretty much any function that involves sin/cos/tan ect is going to involve a Pi somewhere. This isn't surprising because how we define radians. It can also be found frequently when complex numbers come up (usually because of the relationship to geometric and exponential functions).
Hologram0110 said:
@genericusrnme
The trig functions and your e^{ix} are still related to circles, namely the unit circle! o:)
i will be doing maths as my next module..so will be further able to understand the concepts,
thanks for pointing the way...
No problem buddy :biggrin:
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
