Relativity when you divide a trip into small time intervals
1MileCrash
Disclaimer: I am still learning physics. I think about weird things. This results in thoughts like the one that follows.
My understanding of Planck length is that it is the smallest increment of length that can be measured, and to me this implies that an object can only be a whole number of Planck lengths away from another.
Planck time, as I understand it, is the smallest possible increment of time in which any "event" can actually occur. Since it is derived from the time it takes moving at the fastest possible speed across the smallest possible distance, this makes perfect sense.
This also means that 1 Planck length per 1 Planck time = motion at the speed of light.
Does this imply that when any object moves at a speed less than C, it is really spending a fraction of this motion completely stationary?
If I watch a ball moving at 1/2 the speed of light, noting how many Planck lengths it moves per Planck time, the only result that makes sense with the above given is that during half of the Planck time increments, it moves one Planck length, and for the other half of time intervals, it doesn't move at all.
Since I couldn't observe it moving any fraction of a Planck-length, and I couldn't observe anything happen in a fraction of a Planck time, my only conclusion is that in this *thought experiement* is that I would observe it half the time as moving at the speed of light, and half the time not moving at all. In other words, I couldn't observe it moving one-half of a Planck length per Planck time.
Thus, to make my title clear, this means to me, that if something is actually moving, it is moving at C. Any speed witnessed less than C is an average speed based on how much time is spent stationary or spent moving at C - the only two possibilities.
But here's where I get a bit confused.
If an object is traveling at the 50% lightspeed relative to me, and I am Chuck Norris, I should be able to divide the journey into Planck time intervals and see that half the time, it is stationary, and half the time, it is moving at light speed. However, this would also suggest that half the time, it experiences no elapsed time relative to me, and half the time, it experiences the same amount of elapsed time relative to me, suggesting that in total, it experiences half of the elapsed time relative to me. This is of course not the case, as time only elapses 1.154 times quicker at that speed for the traveler relative to me.
So why is it when I divide the trip this way, the relativistic effects don't make sense?
Relativity really isn't meant to "work" with discretization of the underlying space. The problems with doing so are why a theory of quantum gravity elude us so.
Nevertheless, you're correct to say that any object's velocity is c at all times. This exactly gets at the idea of the four-velocity, which is usually denoted u. An object traveling with ordinary (or "three-") velocity v = \beta c in the e_x direction has four-velocity
u = \gamma c (e_t + \beta e_x)
When you take the magnitude of this vector, you always get c, regardless of \beta (note that \gamma = (1-\beta^2)^{-1/2}, which is why the normalization stays fixed).
That's not true, so the rest of what you wrote doesn't follow.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
