Is Potential Constant on a Conductor?
In a connected conductor, the electric potential at any point is uniform, confirming that for an ideal conductor, the potential is the same throughout. However, the absolute value of the potential is arbitrary and can be defined as zero at any chosen point, lacking intrinsic physical significance. In equilibrium, there is no voltage drop, but if charges are in motion, such as in a current, a voltage drop occurs along the conductor. Superconductors maintain a constant current without a voltage drop, even when current flows. Understanding these principles clarifies the behavior of conductors and superconductors under different conditions.
Sogan
Hi,
I consider a connected conductor. Is it right, that:
1)the potential at any point of the conductor is the same, but
2)the absolute value of the potential isn't zero in general?
I think these statements are true, but I'm not sure about it, especially with the second statement.
Thank you a lot!
Regards
For an ideal conductor, yes.
This value has no meaning. You can define "zero" wherever you want. There are some conventions, depending on the setup, but they do not have a physical meaning themself.
in equilibrium :wink:
(if charges are moving, ie if there is a current, then obviously there is a voltage drop along the conductor, ie an electric potential difference)
Thank you very much! Now I understood.
In superconductors with constant current, you have no voltage drop, even with a current flow.
If charges are accelerating, you have an electric field and therefore a voltage drop ;).
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
