Does a Lagrangian preserving transformation obey the equations of motion?
The discussion centers on the challenge of proving that a transformation preserving the Lagrangian leads to solutions that satisfy Lagrange's equations. The original poster is struggling with this seemingly straightforward proof, which is actually complex and relates to Noether's theorem. They note that their textbook claims this without providing a proof, leading to frustration. Other available proofs tend to circumvent the issue rather than address it directly. The conversation highlights the intricacies involved in understanding transformations in Lagrangian mechanics.
dEdt
This seems like such a simple question that I fully expect its solution to be embarrassingly easy, but try as I might I can't get the answer.
Consider some system which can be described by N generalized coordinates q_1,...,q_N and a Lagrangian L(q_i,\dot{q}_i,t). (I'll just use q_i as a stand in for q_1,...,q_N). Let q_i(t) be a solution to Lagrange's equations ie an actual possible trajectory through phase space that the system can follow.
Now we make the transformation q_i(t) \rightarrow Q_i(t) such that the Lagrangian doesn't change. I want to prove that Q_i(t) also satisfies Lagrange's equations.
This seems like it'd be so trivial to prove, and it probably is, but I can't brain today (or yesterday, apparently) and would appreciate your help.
it's not trivial to prove, in fact it's quite the opposite. this is the beggining of the proof of Noether's theorem. I personally don't remember the proof, but you can google it easily.
Unfortunately, I was motivated to ask this question because the proof of Noether's theorem in my textbook asserted this without proof! And all other proofs that I've seen are constructed to avoid the problem.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
