Using Taylor's Theorem and big O
  • Thread starter Thread starter SMA_01
    Theorem
The discussion centers around the application of Taylor's Theorem to approximate the function √(x+1) and to understand the notation O(x^2) in the context of small values of x.
  • The original poster attempts to apply Taylor's Theorem to derive an approximation for √(x+1) and seeks clarification on the meaning of O notation. Other participants suggest expanding the Taylor series and discuss when to stop the expansion.
Participants are actively engaging with the concepts, with some providing clarifications on the Taylor series expansion and the interpretation of O(x^2). There is an ongoing exploration of how to appropriately apply these concepts without reaching a definitive conclusion.
There is a question regarding the stopping point for the series expansion, specifically whether it is appropriate to stop at x^2. The original poster expresses uncertainty about their solution and the meaning of the notation used.
SMA_01
Use Taylor's Theorem to show that
√(x+1)=1+(1/2)x+O(x2)
for x sufficiently small.
Here's what I did:
f(x)= √x+1
f'(x)= (1/2)(x+1)(-1/2)
Then using x0=0,
f(0)= 1, f'(0)=1/2.
√x+1=1+(1/2)x-(1/8)x2(cx+1)(-3/2)
So, then using h as a parameter:
l√(h+1) -1-(1/2)h l ≤ 1/8(h2)
Finally,
√(h+1) = 1+(1/2)h+O(h2)
Is this correct?
I' m having difficulty understanding the meaning of O, can someone please explain in simple terms?
Thank you.
If you expand ##f(x)## in a Taylor series about ##x=0## you get$$
\sum_{n=0}^{\infty} \frac{f^{(n)}(0)}{n!}x^n$$You need to write out the first few terms of that for your function. The notation ##O(x^2)## means the other terms are bounded by a constant times ##x^2##. So you group all the higher order terms together and call them ##O(x^2)##.
LCKurtz- Thank you. I just edited my original question, I think I solved it right, but am not completely sure. How do I know when to stop expanding the series? Is it once I get x^2?
Yes, the terms from ##x^2## and higher are all ##O(x^2)##. I like to think of ##O(x^2)##, very informally mind you, as "Other terms containing ##x## to at least second power". Not very precise but easy to remember.
Much easier to understand, thank you!
  • · Replies 27 ·
