Centrifugal Pressure - Ideal Gas Compressibility Problem
The discussion revolves around the behavior of an ideal gas in a centrifuge, focusing on the effects of compressibility during an adiabatic process. The original poster attempts to derive a pressure equation for a compressible gas and compare it to the incompressible case, raising concerns about discrepancies in the results.
  • Participants discuss the application of the Boltzmann distribution and its relevance to the problem. Questions arise regarding the assumptions made about the gas's behavior under centrifugal forces and the implications of the system being open or closed. There is also consideration of the steady-state conditions and how temperature may vary.
Multiple interpretations of the problem are being explored, with some participants suggesting alternative approaches to integrating the ideal gas law. Guidance has been offered regarding the relationship between pressure differences and centrifugal forces, though no consensus has been reached on a definitive solution.
Participants note the potential impact of the system's configuration (open vs. closed) on the solution and the importance of considering the steady-state conditions in the analysis. There is also mention of the need for clarity in the mathematical expressions used throughout the discussion.
dushak
(see also attached .doc)
There is an ideal gas in the centrifuge; no flows, everything is steady (not very steady in fact - process is adiabatic). If gas is incompressible, it is very easy:
P=0.5 rho (w*r)^2
But my gas is compressible, and it's a trouble.
I started from distribution law of Bolzman (with C = Bolzman constant):
n=n0 exp(mgx/CT)
,hence
d(ln n)=(M * w^2 * r) dr / RT
,where M is molar mass of gas
after integrating this equation (also used PV/T=const and PV^k=const) I got:
P/P0 = { 1 + (k-1)*Mv^2/(2*R*T0) } ^ [k/(k-1)]
,where
k=Cp/Cv
v=w*r
And now goes the trouble. At low velocities (and low compression ratios) the last equation must transform into the first: deltaP=0.5 rho v^2 / 2
But it doesn't! Using the rule (1+x)^a = 1+a*x ,when x<<1 we have:
P/P0 = 1 + k*Mv^2 / 2RT0
deltaP/P0 = k*Mv^2 / 2RT0
deltaP = k*rho*v^2 / 2
,which is k time larger...
So what is wrong? Or anybody have a ready-for-use formula?
P=0.5 rho (w*r)^2
n=n0 exp(mgx/CT)
,hence
,where
k=Cp/Cv
v=w*r
i am interested in the solution, did you find one?
FWIW i don't see what Boltzmann's dist has to do with it, can't you just integrate the ideal gas law with an acceleration correction?
i think it makes a lot of difference if the centrifuge is open or closed at the top, having the constraint of fixed total mass will probably change the form of the solution.
If this is a steady state situation, isn't the temperature constant? Sure there is a transient adiabatic temp change when the centrifuge starts up, but conduction in the gas will get rid of that in the steady state.
So I think you have an ideal gas, with pressure and density varying with radius, and a force dm.r.omega^2 = rho.A.dr.r.omega^2 on the gas between radius r and r+dr.
i think you must have meant to substitute the ideal gas law where one on the centrifugal forces is, as you have it the r.omega^2's just cancel out.
another way to say it, the difference in pressure difference across the layer must be caused by the force on the layer (area cancels, i think)
so: dP=w.w.r.dm=w.w.r.dr.P/RT
integrate over range , P;Po to P and r;0 to r,
so P/Po=K.Exp(w.w.r.r/2RT)
and with w=0, P=Po so K=1
so P/Po = Exp(w.w.r.r/2RT)
does this seem OK?
I was just writng the mass in 2 different ways - sorry if that was confusing.
To be pedantic A.dP = w.w.r.dm (what you wrote says "pressure = force" which isn't right)
and using dm = rho.dV = rho.A.dr the area cancels out and dP = w.w.r.dr.P/RT
11K
