Power supply for solenoid valve
The discussion highlights the differences between AC and DC power sources for solenoid valves, emphasizing that while AC solenoids exist, DC solenoids are typically stronger and more commonly used. Power consumption primarily involves resistive losses in the solenoid coil when activated. Calculating the power used during the pull-in phase remains complex and is not commonly addressed. The choice between AC and DC depends on the available power supply; using a DC supply is advisable if already in place, but adding one solely for solenoids may not be cost-effective. Overall, the application and existing power infrastructure are key considerations in solenoid valve power design.
Aubrey
what's the difference between AC and DC power source for solenoid valve?and what is mainly the power consumed for?
for mature products available, what should be taken into consideration for power design?
thanks
To tell you the truth, I don't think that I've ever heard of an AC solenoid. They probably work the same way as a DC one, but I can't help suspecting that there would be fatiguing vibrations at or around the cyclic frequency of the current. That is, after all, the basic idea of a doorbell buzzer.
I agree with Danger. Certainly the strongest solenoids will use DC power. The power consumed is the resistive losses in the solenoid coil while it holds the slug in tight. I'm not sure how you'd go about calculating the work done and corresponding extra power consumed during the pull-in phase...I just have never gone through that calculation.
AC solenoids are used all the time. Your washing machine most likely uses them to turn on and off the water.
Which to use is a matter of what power you have available. It is not worth the expense to include a DC power supply just to drive a few solenoids. On the other hand if you already need a DC supply, then use it.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
