Determine if G and H are isomorphic
  • Thread starter Thread starter hyderman
To determine if graphs G and H are isomorphic, one must analyze the degree of each vertex in both graphs. The discussion emphasizes that isomorphic graphs have a one-to-one correspondence between their vertices, maintaining edge connections. It is noted that G consists of a 3-cycle and a 4-cycle, while H is a 7-cycle, suggesting they are not isomorphic due to differing structures. Participants stress the importance of clearly defining terms and providing detailed steps in the analysis process. Ultimately, the conclusion drawn is that G and H are not isomorphic based on their vertex degrees and structure.
hyderman
please help by explainig in steps thanks much
Determine if G and H are isomorphic. Justify your answer
http://img252.imageshack.us/img252/9076/25461570nc6.jpg
You must show some work before we can help. One possible approach is to work out the degree of the vertices in each graph and try to identify those in G with those in H.
hello
thanx i know about the dgrees but i still don't know how to determine that somtime the degree fo the vertices does tell you a bout that... so i know step by step details in order to know all possiblities... i appreciate your help
thanx
Very well, do you know what "isomorphic" MEANS? Notice that cristo did not just say "work out the degree" he also said "try to identify those in G with those in H". What have you done toward that? What is the degree of each point in G and each point in H?
okey that's what i have but i still need some one to explain that in steps
For G this graph is made of
a 3-cycle agc,
a 4-cycle hdbf.
For H this graph is made of
a 7-cycle 2583647. C
so G and H are not isomorphic
i am not sure if this iright or wrong and the same time i need some explanation so i can be sure for what i am doing
thanc
You've not answered Halls' question: what does isomorphic mean? What is the degree of each vertex of G and each vertex of H?
Also, I don't understand your notation: what, for example, does the cycle agc mean? I would presume it to mean an edge from a to g, another from g to c and a third from c to a; but there is no edge from a to g in the graph G! Please explain your notation.
Isomorphic means same shaped,,,,,,,, now i need explanation
i tried to follow some examples with no luck
You need to be more precise-- "same shaped" is not a mathematical definition of two isomorphic graphs.
Have you read the rest of my last post? Please answer my questions-- I will not tell you the answer without you putting some effort into solving the problem.
isomorphic:
Two graphs are isomorphic if there is a one-to-one correspondence between their vertices and there is an edge between two vertices of one graph if and only if there is an edge between the two corresponding vertices in the other graph.
G:
a-5 degrees
b-5
h- 5
for
H:
1-6 DEGREES
2-4
3-5
4-5
8-5 DEGREES
