Hello, I am currently planning on constructing an electromagnet.
The discussion revolves around constructing a powerful electromagnet for entertainment purposes, specifically designed to support 300-400 pounds for climbing or hanging. Key considerations include the choice of materials, such as using a soft iron core, and the appropriate gauge of magnet wire. Participants suggest that while pre-made options like those from EftonScience exist, the original poster prefers to build the electromagnet themselves. The conversation emphasizes the importance of the winding amount, core radius, and current specifications for optimal performance. The desire for a DIY project highlights the enjoyment of the construction process itself.
Chronothread
Hello, I am currently planning on constructing an electromagnet. Its purpose is entirely for entertainment. I was hoping to make two of them that I could attach handles and switches to so they could be used for hanging/climbing underneath some random thing. If possible, it would be useful if they could hold up at least 300-400 pounds to make sure they don't fail if the person using them were to apply force the wrong way with some sort of accidental movement. I was just wondering what material of magnet wire, gauge of wire, and type of core should be used. I'm guessing some sort of soft iron core, but I'd like specifics if possible. As for the wire, I don't know enough about wire yet to figure it out without asking. And although I can probably figure the rest of the magnet out pretty easily myself, if you'd like to throw in some recommended amount of windings, radius of core, or amount of current I'd be happy to hear. Thank you for time.
Computer science news on Phys.org
If you'd like to save yourself a lot of hassle, you can just go to EftonScience (I believe that it's the renamed version of 'Edmund Scientific Company'). They (used to, at least) have an electromagnet that's about 2" in diameter by 1" high, runs on a couple of D-cell batteries, and can lift 200 lbs.. It also has an eyelet bolt built in for attachment purposes.
A couple of those things would stick you to a ceiling beam so tight that Spidey's dear old Aunt May herself couldn't pry you off with a Teflon spatula.
If you insist upon building your own, however, I can be of no help to you. Sorry.
Yah, part of the entertainment is the building process, so I would like to actual make it myself, but thanks for the suggestion.
Danger said:
...you can just go to EftonScience
Either you live in Hogtown or there is more than one Efton Science in the world.
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
