Perturbation of the simple harmonic oscillator
nowits
[SOLVED] Perturbation of the simple harmonic oscillator
An additional term V0e-ax2 is added to the potential of the simple harmonic oscillator (V and a are constants, V is small, a>0). Calculate the first-order correction of the ground state. How does the correction change when a gets bigger?
E_0^1=<\psi_0^0|H'|\psi_0^0>
\alpha=\frac{m\omega}{\hbar}, E_0^1=\int ^{\infty}_{-\infty} (\frac{\alpha}{\pi})^{1/4}e^{-\alpha x^2/2}V_0e^{-ax^2}(\frac{\alpha}{\pi})^{1/4}e^{-\alpha x^2/2}dx=(\frac{\alpha}{\pi})^{1/2}V_0\int ^{\infty}_{-\infty} e^{(-\alpha -a)x^2}dx
So I suppose this is not what is wanted.
What makes you think this is not right?
Have you tried to compute the integral? It's a standard one.
\int e^{-\xi x^2}=\frac{\sqrt{\pi}\ erf(\sqrt{\xi}x)}{2\sqrt{\xi}}\ \ \ ?
I've never encountered an error function before in any homework problem, so I automatically assumed that I had done something wrong.
That's right, the indefinite integral contains an erf.
But you have more information: you know the boundary conditions and (you should have) \xi > 0. Using
\lim_{x \to \pm \infty} \operatorname{erf}(x) = \pm 1
you can calculate it, and in fact it is just a Gaussian integral,
\int_{-\infty}^\infty e^{-\xi x^2} dx = \sqrt{\frac{\pi}{\xi}}
Remember this -- it's ubiquitous in physics (at least, every sort of physics that has to do with any sort of statistics, amongst which QM, thermal physics, QFT, SFT).
Ok.
Thank you both!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
