Calculating Speed and Direction of Sailboat After Gust of Wind
The discussion focuses on calculating the speed and direction of a sailboat after a gust of wind. The initial speed is 5 m/s east, with an acceleration of 0.80 m/s² at 40 degrees north of east. To find the boat's speed after 6 seconds, the acceleration must be broken into east and north components. The correct approach involves calculating the final velocity components separately and then combining them to determine the resultant speed and direction. The initial calculations incorrectly assumed the acceleration was perpendicular to the velocity, leading to inaccurate results.
Kster
A sailboat is traveling east at 5m/s . A sudden gust of wind gives the boat an acceleration=.80 m/s^2, (40 degrees north of east).
A. What is the boat's speed 6 seconds later when the gust subsides?
________m/s
B. What is the boat's direction 6 seconds later when the gust subsides?
________degrees north of east.
My attempts:
v = v0 + at
v = (0) + (0.80m/s^2)* (6sec)
v = 4.8m/s
A^2+ B^2 = C^2
(4.8)^2 + (5.0)^2 = 48.04
C= 6.9 m/s
_____________________
tan-1 (4.8/5.0) = 44°
Please tell me what I did wrong? I am so stuck :(
Kster said:
A^2+ B^2 = C^2
C= 6.9 m/s
This assumes that the acceleration is perpendicular to the original velocity (east). But it's not: the acceleration is 40 degrees north of east.
Hint: Break the acceleration (and the velocity) into components (east and north). Find the final velocity component east and the final velocity component north, then you can combine them to find the final speed.
Another approach is to find the change in velocity along the direction of the acceleration, which will be some vector 40 degrees north of east. Then just add that vector to the initial velocity vector and find the new magnitude.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
