Homework (Initial velocity, gravity, and falling height)
To solve the problem of a physics book sliding off a table, the key equations involve the concepts of initial velocity, gravity, and time. The book's initial vertical velocity is zero, while its horizontal velocity remains constant at 1.10 m/s. To find the height of the tabletop, the equation h = 1/2 * g * t^2 can be used, where g is the acceleration due to gravity (9.8 m/s²) and t is the time (0.350 s). The horizontal distance can be calculated using the horizontal velocity and time. The discussion emphasizes the importance of correctly applying these equations to determine the height and distance accurately.
RawTalent
Hey I am having a bit of trouble finding the proper equation to use when solving a problem such as this...
A physics book slides off a horizontal tabletop with a speed of 1.10 m/s. It strikes the floor at 0.350 s. Ignore air resistance. Find (a) the height of the tabletop above the floor, (b) the horizontal distance from the edge of the table to the point where the book strikes the floor, and (c) the horizontal and vertical components of the book’s velocity, and the magnitude and direction of its velocity, just before the book reaches the floor.
I used this equation with no success...
1.10(.35)+1/2(-9.8)(.1225)
= .385 + (-.60025)
= -.215 m
where do i go from here? Thanks.
Hi Raw Talent, welcome to PF.
When the book leaves the table top, its velocity in the downward direction is zero and in the horizontal direction is 1.1 m/s, which remains costant.
So substituting 0 m/s for initial velocity I end up with .6 meters. I am still unsure if that's correct. Can anybody tell me if I'm using the correct equation?
Use h = 1/2*g*t^2 and find the answer.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
