Average Speed/Average Velocity Problem
  • Thread starter Thread starter pitchharmonics
    Average Velocity
To solve the average speed and average velocity for the trip from City A to City C, the total distance and time must be calculated, taking into account the angles for each leg of the journey. The average speed is determined by dividing the total distance traveled by the total time, including the 10-minute stop. For the return trip from City E to City A, the same method applies, factoring in the additional time spent at each city. The distinction between speed and velocity is emphasized, with speed being a scalar and velocity a vector quantity that considers direction. Breaking down the journey into x and y components for each vector is a recommended approach to accurately calculate the average velocity.
pitchharmonics
I have a physics problem here that I need help solving. I need to figure out how to find the average speed and average velocity of a trip.
City A to City B is 55 miles with an angle 7.86 degrees west of north.
City B to City C is 75.5 miles with an angle 25.9 degrees west of north
City C to City D is 208 miles with an angle of 41.1 degrees west of north
City D to City E is 98.8 miles with an angle of 5.45 degrees north of west
----I take one 10 minute stop to fill up gas.
Then I return taking a scenic route:
City E to City F is 89 miles with an angle of 24.1 degrees east of south
City F to City G is 23.6 miles with an angle of 14.8 degrees east of south
City G to City H is 194 miles with an angle of 41.2 degrees south of east
City H to City A is 88.0 miles with an angle of 18.4 degrees south of east
--------I spend 45 minutes at each city on the way back
--------Average Speed for entire trip is 53.7 mi/h
1. what is the average speed and average velocity from City A to City C?
2. what is the average speed and average velocity from City C to City E?
3. What is the average speed and average velocity from City E to City A on the return?
Any help would be greatly appreciated!
Any help might be given if you show some of your own work! :wink:
Do I break this down into all the x and y components? of each vector?
Our book uses average speed and average velocty as if they were the same, what is the main difference
Velocity is a vector quantity; speed is the (scalar) magnitude of that quantity.
speed = total distance / total time
velocity = change in displacement/change in time
r cos angle= x component
r sin angle= y component
this is all I know
