What is the potential difference across the capacitor?
The discussion focuses on calculating the potential difference across a parallel-plate capacitor with specified dimensions and charge. The relevant equations include capacitance (C = Q/V) and the formula for capacitance in terms of physical parameters (C = epsilon * A/d). The user has calculated the area of the plates and the separation distance but is struggling with the final calculation, having tried several incorrect values. Another participant mentions having similar issues but eventually resolves their calculation errors. The thread emphasizes the importance of showing detailed calculations for clarity and accuracy.
Netsurfer733
"Two 2.1cm x 2.1cm plates that form a parallel-plate capacitor are charged to +- 0.705 nC. What is the potential difference across the capacitor if the spacing between the plates is 1.20mm? "
C = Q/V
C = epsilon * A/d
I figure epsilon = 8.85 x 10^-12 F/m
A = area of plates = 0.021 * 0.021 m^2
d = separation of plates = 1.2 x 10^-3 m
And so I've tried plugging it all in and I still didn't get it right. In my attempts, I've tried answering with 2.17, 3.25*10^-12 , and 2.16*10^11 with no luck. Can anyone point out where I've gone wrong?
Have you calculated the potential difference or just tried numbers in random? Show your calculations in detail.
ehild
I did - but I apparently suffered a flurry of math errors. I got it anyway :)
