Calculating World Line for Least Proper Time: An Easy Question on Relativity
  • Thread starter Thread starter teddd
    Proper time Time
teddd
Hi everyone!
Let's take two events P_1,P_2 in a Minkowsky spacetime, and let's choose them both lying on the \omega axis, separated by a certain distance.
Now, I want to calculate the world line of the particle which experiences the least proper time during its trip between the two points.
The proper time, taking the velocity of the particle costant in its modulus (but not in its direction!) can be written d\tau=dt\sqrt{1-v^2/c^2}=dt\sqrt{dt^2-dx^2/c^2}=\frac{1}{c}\sqrt{dw^2-dx^2}; so it's easy to set up a variational calculus, minimizing the integral\tau=\frac{1}{c}\int_{P_1}^{P_2}\sqrt{1-\left(\frac{dx}{d\omega}\right)^2}d\omega(the quantity under the square root can't be negative, you all know why:smile:).
So by taking L=\sqrt{1-{x'}^2(\omega)} with x'(\omega)=\frac{dx}{d\omega} we need to calculate the euler-lagrange equation:\frac{\partial L}{\partial x(\omega)}-\frac{d}{d\omega}\frac{\partial L}{\partial x'(\omega)}=0but since L doesn't depend on x(w) but only on x'(w) we get to\frac{d}{d\omega}\frac{\partial L}{\partial x'(\omega)}=\frac{d}{d\omega}\frac{x'(\omega)}{ \sqrt{1-{x'}^2(\omega)} }=0and so \frac{x'(\omega)}{ \sqrt{1-{x'}^2(\omega)} }=G\Rightarrow x'=\frac{G}{\sqrt{1+G^2}} where G is a constant, determinable by the position of the two point on the spacetime.
So we end up withx(\omega)=\frac{G}{\sqrt{1+G^2}}\omega
This is supposed to be the path between the two point on the spacetime of the particle which experiences the least proper time.
In the case considered in the beginning I took both point lying on the w axis; so the constant G turns out to be 0, so the path I'm looking for is x=0, which corresponds to a particle at rest.
But this is impossible, since it's know that this path it's the one with the longest proper time!
I found various solution for this:
1) I did not understood nothing of relativity
2) I've done various mistake
3) The variational method I've used gave me effectively an extremal path, but the longest, not the shortest. If so, does this means that there are not a minimum path? (I don't think so) OR I have to introduce some lagrange multiplier-style constraint on the calculation (like the fact that I cant'get back in time)??
Can you help me to solve this riddle??
Thanks for your disponibility!
The Euler Lagrange equation only guarantees 'stationary' variation. It does not distinguish minimum, maximum, or saddle (neither). There are other conditions you can test for that distinguish these case (these are rarely worth the bother - you can normally figure out which you have). However, in relativity, the answer is simple: there is no extremal minimum. A light like path has zero proper time but is not stationary with respect to variation. A time like path can get arbitrarily close to zero proper time. Bottom line: variation of a Minkowskian metric only gives you curves of maximum proper time (in GR, it doesn't guarantee that - there are often saddle geodesics in GR which have non-extremal paths of both longer and shorter proper time).
Thanks PAllen!
But can you make clear to me why it can't be found any minimum path for a world line?
The proper time can be made arbitrarily small if the world line to which it corrisponds can get close enough to the null geodesic, but if the path has to pass between fixed point there are some constraint!
I imagine that the path which have the shortest proper time is kind of the "longest" one. So if I take some oscillating function x=Asin(aw) that meets the requirement of a timelike path and whose tangent is the closest possible to the lightlike path i guess that something has to come out; but again I realize now that the higher the frequency the longest the path, so effectively there is no minimum. Am I right?
teddd said:
Thanks PAllen!
There is no variational minimum. Given any time like path between two events, there is a 'nearby' path that has lower proper time. As a result, the Euler-Lagrange equation will never pick out a minimum for paths between events with time like separation.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
