Understanding the Balance: Equal Weight, Unequal Position
A common balance achieves a horizontal position due to the principle of equilibrium, where the torque around the center must be zero for stability. Even when tilted, the potential energy remains constant as the increase in potential energy from one mass moving up is balanced by the decrease from the other mass moving down. The restoring torque arises from the weight of the pointer when the scale is unbalanced, calculated by the formula involving the weight of the pointer, the distance from the pivot, and the angle of tilt. The discussion highlights that scales operate in a closed-loop manner, ensuring accurate measurements despite variations in mass. Understanding these principles clarifies how balances maintain equilibrium and function effectively.
krishna mohan
Confused about a simple thing...
For a common balance, since both arms have equal weight, what causes the pole to choose a horizontal position?
Shouldnt it be stable in any other position as the torque around the centre is zero for any other position too?
The arms of the balance move up and down, leaving the only position for equilibrium as exactly straight, for equal mass arms.
I am a little confused here...
Even if you move the balance to some other position, the potential energy is not going to change..as the increase in PE due to one mass moving up is compensated by the decrease due to the other moving down..
In a slightly tilted position, where does the restoring torque come from? The two masses seem to contribute equal and opposite torque leading to zero torque...
If the pointer points below the pivot point then if the scale is unbalanced the pointer provides a restoring torque = W*l*sina where W = weight of pointer, l = distance from pivot to pointer's c.g. and a = offset angle. Since scales are always balanced with known weights, the "open-loop" quantity da/dm is of no first-order importance. Scales are always used in a closed-loop manner.
I don't know much about scales but I would think that's how they're designed.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
