Probability: Independent vs. Dependent events
trojansc82
2. Let a random experiment be the cast one “six-sided” die and one “four-sided” die.
(a) Give an example of two independent events and justify your answer.
(b) Give an example of two dependent events from this sample space and justify your answer.
Independent event:
P(A ∩ B) = P(A) * P(B|A) = P(A) * P(B)
Dependent event:
Not Independent, i.e. P(A) * P(B) = P(A ∩ B)
A = {(1,1), (1,2)}
B = {(1,1), (2,1)}
P(B) = P(B|A) = P(A ∩ B)/P(A) = (1/24)/(2/24) = 1/2
P(B) is not equal to 1/2
Independent event:
Dependent event:
A = {(1,1), (1,2)}
B = {(1,1), (2,1)}
No one has replied, possibly because your work is so terse, making it difficult to understand.
Are A and B the two events? What do they represent (in words)?
On one line you say that P(B) = 1/2, and on the next line you say that P(B) is not equal to 1/2. How can a given probability be equal to and also not equal to the same number?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
