Velocity from acceleration if acceleration is a function of space
The discussion explores the implications of defining acceleration as a function of space, a(x), rather than time. Participants clarify that while acceleration is typically the time derivative of velocity, it can also be expressed in terms of position, leading to a relationship between velocity and position through integration. The chain rule is utilized to connect these variables, resulting in equations like v dv = f(x) dx, which can be integrated to find velocity as a function of position. The conversation also addresses the confusion surrounding whether velocity should be considered a function of time or space, ultimately concluding that both perspectives can coexist depending on the context. The discussion emphasizes the mathematical legality of deriving functions with respect to different independent variables.
fisico30
Hello Forum,
usually the acceleration a is a function of time: a(t)= d v(t) /dt
to find v(t) se simply integrate v(t)= integral a(t) dt
What if the acceleration was a function of space, i.e. a(x)?
what would we get by doing integral a(x) dx? The velocity as a function of space, v(x)?
but a(x) is not defined to be v(x)/dx or is it? maybe some chain rule is involved..
thanks,
fisico30
fisico30 said:
What would we get by doing integral a(x) dx? ... chain rule ...
You use chain rule
a(x) = dv/dt = f(x)
multiply dv/dt by dx/dx:
(dv/dt)(dx/dx) = (dx/dt)(dv/dx) = v dv/dx = f(x)
multiply both sides by dx
v dv = f(x) dx
If f(x) can be integrated and the integral of f(x) = g(x), then
1/2 v2 = g(x) + c
This results in an equation that relates velocity and position.
v = sqrt(2 (g(x) + c))
To get time versus position, you start with
v = dx/dt = sqrt(2 (g(x) + c))
and then integrate
dx/(sqrt(2 (g(x) + c))) = dt
assuming h(x) is the integral of dx/(sqrt(2 (g(x) + c))), you get
t = h(x) + d
where d is constant of integration. It may be possible to solve this equation to get x = some function of t.
One simple case is a(x) = -x, which results in x(t) = e(sin(t+f)), where e and f are constants.
Thanks rgcldr!
great explanation and example!
fisico30
Hi rcgldr,
one question:
when you get v dv = f(x) dx, is v a function of t or of x, i.e. is v equal to v(t) or v(x)?
It looks like it would be a function of x, v(x), since 1/2 v^2 = g(x) + c results in v(x) = sqrt(2 (g(x) + c)).
I am confused because when we write v=dx/dt I always assume that v must be a function of time t, i.e. v(t).
When in your first step you write a(x) = dv/dt I tend to think that the v must be function of t since dv/dt is a derivative with respect to time.
So which one is correct? a(x)= dv(x)/dt or a(t)=dv(t)/dt. Acceleration is always the time derivative of the velocity vector but the velocity vector can be a function of any dependent variable: v(t), v(x), v(F), where F is force, etc...
Thanks,
fisico30
I guess my point is: if a function, like a, is defined as a time derivative of another function, dv/dt, does the differentiated function need to be a function if time?
fisico30 said:
when you get v dv = f(x) dx, is v a function of t or of x, i.e. is v equal to v(t) or v(x)? It looks like it would be a function of x, v(x), since 1/2 v^2 = g(x) + c results in v(x) = sqrt(2 (g(x) + c)).
At this point, it's just a relationship betwen v and x.
It is, but I was only able to take advantage of that in the last step where I find t as a function of x.
True, but I used chain rule to get rid of the dt and end up with v dv = f(x) dx.
Both are correct, but if acceleration is defined as a function of x, then it may not be possible to find an equation for acceleration as a function of time. In the simple example I gave, a(x) = -x, you will be able to find both a(x) and a(t). I ended up finding x(t) = e sin(t + f). You can take the derivative of this to find v(t), and the derivative of v(t) to find a(t), so a(x) = -x, and a(t) = -e sin(t+f). For other situations, you may not be able to solve for x(t), v(t), or a(t), in which case numerical integration will be required.
So it is mathematically legal and ok to write a derivative of a function even if
the independent variable a of the function and the differentiation variable b are not the same: f(a) and db to create df(a)/db...
I guess that is all the chain rule is about...
