Drag coefficient for plate perpendicular to airflow
The drag coefficient for a flat plate perpendicular to airflow is typically between 1.98 and 2.05, as noted in the discussion. The specific dimensions of the plate (b/h ratio of 5.197) do not significantly alter this coefficient, especially since the flow conditions are primarily pressure drag. The Reynolds number is less critical for this configuration, as the flow will create vortex streets regardless of whether it is laminar or turbulent. For accurate results, consulting references with similar measurements is recommended. Overall, the established drag coefficient range remains applicable for the described scenario.
cxcxcx0505
http://en.wikipedia.org/wiki/Drag_coefficient
from wikipedia, it is written 1.98-2.05 for flat plate perpendicular to flow(2D) , but I have a differrent b/h ratio plate, where h=157mm and b=816mm , b/h=5.197
how to get the drag coefficient in this case?
Thanks.
What are your flow conditions?
Laminar? Turbulent?
Are we just talking about ambient air? or God blowing on the plate... =)
Give me the Reynolds number and I can help you out.
Cheers =)
For a plate perpendicular to the flow the reynolds number will not matter much. That wikipedia page gave a Cd for a 3d flat plate and you will probably be ok using that. Otherwise there is not an easy way to figure this out, your best bet would be to find some reference with similar measurements
Laminar? Turbulent?
Cheers =)
Given that this is going to be entirely pressure drag, the state of the flow (laminar vs. turbulent) won't matter a bit. The only thing that could potentially play a role in would be the nature of the vortices that would be shed behind the plate, but the aft side is going to be massively separated and emitting vortex streets regardless.
Apologies,
Did not properly read OPs question. I thought he was talking about parallel flow on plate.
Whoops =)
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
