This is lifted from the wiki article that isometricpion references who was rather kind and polite about the whole thing, I cannot say the same thing for you, number nine:
No evidence exists to suggest that the boundary of the observable universe constitutes a boundary on the universe as a whole, nor do any of the mainstream cosmological models propose that the universe has any physical boundary in the first place, though some models propose it could be finite but unbounded, like a higher-dimensional analogue of the 2D surface of a sphere which is finite in area but has no edge
This website puts the size of the whole universe at 93 billion light years
http://scaleofuniverse.com/
I'm aware that many mainstream physicists believe the size of the whole universe is infinite. For instance here's Stephen Hawking:
in the third kind of Friedmann model, with just the critical rate of expansion, space is flat (and therefore is also infinite
I have not yet heard any decent reason why anyone would think it is infinite and when I say infinite I mean that there is no limit on how many particles, planets or stars it has. If you're talking about a different kind of infinity that you're committing the fallacy of equivocation.
I'm not sure there any point in debating with you, number nine. You use insulting language such as:
I'm tempted to dismiss this as deliberate stupidity. ... I'm going to go right ahead and accuse you of being deliberately ignorant, here.
When you're opponent starts to use language like that he's doing it to cover up the weakness of his position.
You also fail to answer my points. I can't debate with someone who will not answer the questions I put to him. I asked you to prove how metric expansion implies that space is infinite and you failed to do that. There is nothing in metric expansion that makes space infinite. This is lifted from the wiki article on metric expansion:
The metric expansion of space is the increase of distance with time between distant parts of the universe. It is an intrinsic expansion—that is, it is defined by the relative separation of parts of the universe and not by motion "outward" into preexisting space. The universe is not expanding "into" anything outside of itself. A frequently used 2-D analogy is the expansion of the surface of an expanding rubber balloon.
D= RT still applies you just have to calculate rate differently, that is you have to factor in how much space expands while you're crossing over it. The product of two finite numbers is still finite.
I've also asked you three times for an explanation of this quote:
The universe doubled in size in a fixed time and then doubled again in that same time and then kept doubling at least 90 times in a row until the inflationary epoch ended and the universe was as smooth as we see it today. This exponential expansion means, for example, that when the universe’s age had multiplied by 60 times, the size of the universe would have increased by more than a trillion trillion trillions in size.
It's been my experience that when they refuse to answer a point the first time they rarely answer it when you ask them again.
I asked you to go ahead and calculate the probability of a number being prime and you didn't but said that someone else has done it.
Odd numbers constitute 50% of the integers. The fact that there are an infinite number of integers is irrelevant.
Odd numbers are abstract objects they are true by definition. You can't compare abstract objects with concrete objects. There are 50% odd numbers by definition. You can't say:
"I can calculate the odds of an abstract entity, therefore I can calculate the odds of an empirical entity."
Odd numbers are in no way comparable to concrete, ordinary matter. The ratio of a finite patch of space to infinite space is practically zero. Your sample size of the what you can observe compared to what you think exists is next to nothing. It would be ludicrous to extrapolate from an extremely tiny sample to the whole infinite universe if there is an infinite universe.
Because right in my previous post I gave you the example of the normal distribution, whose domain is the reals.
I'm talking about an example in the
real world not an example from the abstract world of mathematics that doesn't exist. Go ahead and tell me the probability of finding a certain type of matter in a universe of infinite size and I'm not talking about the matter restricted to our light cone. I want you to calculate the density of matter in an infinite universe.
