ANSYS Basics Help: Is Meshing Necessary?
  • Thread starter Thread starter ashishvinayak
    Ansys Basics
Meshing is essential for all simulations using Finite Element Analysis (FEA), as it discretizes the geometry into smaller elements for accurate results. While 2D truss problems may not require traditional meshing, tutorials often recommend it for consistency and to align with FEA practices. Meshing can also be applied in 1D for beam elements, not just in 3D scenarios. The preprocessor in ANSYS can be complex, but alternative preprocessors like Ansa offer broader compatibility and user-friendly features. Understanding when to mesh is crucial for effective simulation outcomes.
ashishvinayak
I've been studying ANSYS v11 from a book I bought online. I remember doing the same during my graduation. Now that I am studying in-depth I'd like to know why meshing is required (in more technical terms). Also, I am solving 2D truss related problems where I realize meshing is not done. However, when I checked online 2D truss tutorials suggest implementation of meshing. So what's the right answer? Is it necessary?
Ps. Additional question: I assumed that meshing is something which is attributed only to 3D members. Is this correct?
Please help.
Hi!
about meshing, you can do 1D meshing (if you are working in beams) 2D or 3D
I'm not good at ansys, but I've found that preprocessor in Ansys is somehow messy and difficult to get used to. I use a magnificent preprocessor called Ansa (I use one of latest versions, 13.1. If you google around you can find it easy, and the good thing about it, is that has capabilities of beeing preprocessor for Ansys, Abaqus, Nastran, Pam crash, etc etc etc
I could use that but that wasn't my question really. I'd like to know when meshing should be used and when it should not be used ?
Meshing is required for all simulations using Finite Element Analysis. You will have to use meshing whenever you try and use programs that use FEA.
Some info on FEA http://www.sv.vt.edu/classes/MSE2094_NoteBook/97ClassProj/num/widas/history.html
and the wikipedia article. (Check the references)
http://en.wikipedia.org/wiki/Finite_element_method
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
