Differential pair, current mirror: high frequency analysis
The discussion focuses on the high-frequency response of MOSFET and BJT differential pairs when polarized by a current mirror. It highlights that the bypass capacitor Cgdm is significant at lower frequencies compared to the internal capacitances of the transistors. The Sedra-Smith textbook is referenced, explaining that the interaction between the output resistance (2r0) and Cgdm results in a low-frequency zero, while other internal capacitances can be treated as open circuits. This understanding is crucial for analyzing the frequency behavior of differential amplifiers.
  • Understanding of MOSFET and BJT differential pairs
  • Knowledge of current mirror configurations
  • Familiarity with small signal models in circuit analysis
  • Basic concepts of frequency response in electronic circuits
  • Study the high-frequency response of MOSFET differential amplifiers
  • Explore the role of bypass capacitors in analog circuits
  • Learn about the Sedra-Smith textbook and its applications in circuit design
  • Investigate the effects of internal capacitances on circuit performance
Electrical engineers, circuit designers, and students studying analog electronics who are interested in the frequency response of differential amplifiers and current mirrors.
eliotsbowe
Hello, I have a doubt about the high frequency response of the MOSFET (or BJT as well) differential couple in the case it's polarized by a current mirror.
Here's a picture of my issue (it shows the semi-differential circuit of a MOSFET differential couple with a "small" common mode ac input; the current mirror was replaced by its high frequency small signal model)
http://s3.postimage.org/x84o1dsxv/asdasd.jpg
The picture says (sorry for posting a non-english text) that Cgdm is to be considered a bypass capacitor and the MOSFET should be replaced by its low frequency (!) small signal model.
The sense of this is that Cgdm "exists" at much lower frequencies than the internal capacitances of the MOSFETs composing the differential couple.
I found the same statement about the BJT differential couple (with a BJT-based current mirror connected to the emitter): the internal capacitance of the mirror dominates the low frequency response of the whole circuit and it acts like a bypass capacitor.
So, my question is: why is there such a difference between the "life" (on the frequency axis) of the capacitance of the mirror and the one of the internal capacitances of the two main transistors?
Thanks in advance for your help.
I found it. The Sedra-Smith's book says that the interaction between 2r0 and Cgdm creates a low frequency zero. Every other internal capacitance is to be considered as an open circuit, then.
9K
  • · Replies 18 ·
