Magnetic moment in a uniform/non-uniform magnetic field?
The discussion clarifies the differences between uniform and non-uniform magnetic fields. A magnetic moment experiences torque in both types of fields but only experiences a force in a non-uniform field. It is established that a solenoid generates a uniform magnetic field, while the magnetic field outside an electromagnet is non-uniform. The characteristics of the magnetic field of a magnetic dipole are also referenced as commonly found in textbooks. Understanding these distinctions is crucial for applications involving magnetic moments in various fields.
Wiz700
Hello,
What's the difference?
Being in a uniform or nonuniform magnetic field?
If a magnetic moment(magnet) is place in both, what is the result?
And, is an electromagnet's magnetic field uniform or nonuniform?
I do know that a Solenoid is uniform, but not sure about an electromagnet though.
A magnetic moment will experience a torque in any magnetic field.
It will only experience a force in an inhomogeneous magnetic field.
The magnetic field outside an electromagnet or a finite length solenoid is nonuniform.
It is the field of a magnetic dipole, which is given in most textbooks.
Thanks.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
