Deriving the Center of Mass of a Cone with Point Facing Downwards
To find the center of mass of a cone with its point facing downwards, the discussion focuses on using calculus to derive the center of mass formula. The cone is treated as a stack of disks, where the radius of each disk varies linearly with height. The volume of each disk is expressed as Dv = π[(r/H)x]^2 dx, leading to the integration of x from 0 to H. The calculations yield the center of mass at 3/4 H, confirming the conventional result of H/4 for the center of mass location. The integration approach emphasizes the importance of understanding the geometry and volume of the cone's structure.
dowjonez
I need to find the center of mass of a cone with point facing downwards, of height H and radius R.
Since the density is constant throughout and because of axial symmetry the center must be somewhere on the z-axis.
I know from convention that this is H/4 but i need to derive this.
Rcm = (intregral from 0 to H) of the change in radius
this is where I am stumped
i did really bad in calculus
could anyone help me?
Hint: Consider the cone as a stack of disks.
Let Dv Be An Element In The Form Of A Disk That Cuts Through The Cone.
The Radius Of The Disk Is (r / H) X.
The Volume Equals The Area Of The Disk Times The Thickness.
Dv = Pi[(r / H ) X] ^2
Now Intergate From 0 To H
X' = Int (x Dv) / Int Dv = 3/4 H
okay so the biggest such disk would have volume pi*R^2*h
what is the volume of the disk under that?
the biggest *THIN* disk, at x = H, has radius r = xR/H,
so its Volume = dV = pi R^2 dx.
You need to integrate x from 0 to H .
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
