Is the Earth Flat? An Analysis of Spacetime Curvature
  • Thread starter Thread starter markintheworld
    Earth Flat
markintheworld
This is a bit of a lark, but I'm just wondering if I've understood correctly to draw my conclusion...
It is my understanding that the curvature of spacetime postulated by GR is what causes orbits which appear elliptical. An orbiting body is following its inertial path which might otherwise be a straight line, but due to the curvature of spacetime caused by a nearby massive object, that straight line appears curved, as if the orbiting body were traveling around the edge of a depression. So the moon is traveling in a straight line (its inertial tendency), but because it is near the earth, a massive gravitational object, it APPEARS to be traveling a curved path. Am i correct so far?
Assuming the above is true, that a straight path can appear curved due to the distorting effects of gravity, couldn't it also figure that a flat plane could appear similarly curved? Couldn't it be true that the surface of the Earth is a flat plane, but the curvature of space-time caused by its own gravity is the reason that it appears spherical? Is this why large gravitational objects generally appear to be spherical? Or is there some flaw in my logic?
Insight would be appreciated...
Inertial path doesn't automatically mean straight line. The straight line is a special case. When something follows an inertial path/geodesic/maximizes proper time & all that it may be going straight or not depending on the geometry.
No in GR theory this is not the case!
An orbiting body is traveling on a geodesic but a geodesic is not necessarily a straight line!
See for a detailed discussion on this subject see the last few pages of: https://www.physicsforums.com/showthread.php?t=126871"
Using standard rulers, the surface of the Earth cannot be flat, because it has a non-zero "curvature tensor".
Similarly, space-tme cannot be flat around the Earth, either, because space-time has a non-zero "curvature tensor".
This is assuming that one defines the rather fuzzy English word "flat" with the mathematical defintion "zero Riemann curvature tensor".
The longish quote from Einstein in the thread
https://www.physicsforums.com/showthread.php?t=123922
may give some insight. This is the quote about rulers on a heated slab, as per the title of the thread above.
Let us now imagine that a large number of little rods of equal length have been made, their lengths being small compared with the dimensions of the marble slab.
For a more mathematical approach that defines what curvature means in 3dimensions, see for instance "Gaussian curvature" in the wikipedia
http://en.wikipedia.org/wiki/Curvature
Gaussian curvature is however in fact an intrinsic property of the surface, meaning it does not depend on the particular embedding of the surface; intuitively, this means that ants living on the surface could determine the Gaussian curvature.
An intrinsic definition of the Gaussian curvature at a point P is the following: imagine an ant which is tied to P with a short thread of length r. He runs around P while the thread is completely stretched and measures the length C(r) of one complete trip around P. If the surface were flat, he would find C(r) = 2πr. On curved surfaces, the formula for C(r) will be different, and the Gaussian curvature K at the point P can be computed as
<br /> K = \lim_{r \rarr 0} (2 \pi r - \mbox{C}(r)) \cdot \frac{3}{\pi r^3}
to be successful at measuring curvature, note that it is assumed that the ants have rulers.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
