| Thread Closed |
Why does light have invarient speed? |
Share Thread | Thread Tools |
| Jan7-08, 08:57 AM | #52 |
Why does light have invarient speed?[tex]v_1 = -v_2[/tex] the denominator is not zero but [tex]1 - v_1^2/c^2.[/tex] |
| Jan7-08, 09:58 AM | #53 |
| Jan7-08, 04:56 PM | #54 |
Hi rbj,
Many thanks for all the effort to answer my question. I think the disconnection between your reasoning and my question is about the understanding of what role the light speed constancy plays in SR. It seems to me that you think that’s implied by the principle of relativity. However, this would mean that Einstein could do away one of the two of his postulates. Since Einstein did not do that, it then follows (blindly, or out of my laziness) that light speed constancy must be independent of and thus can’t be explained by the principle of relativity. But I am having a second thought. I am not exactly sure why Einstein had to postulate light speed constancy. One explanation is as stated at http://en.wikipedia.org/wiki/Introdu...ial_relativity that the postulate is needed to establish Maxwell’s equation in the time-space 4D space. For the lack of knowledge on Minkowski's formula and my rusty math, I don’t know how this point worked out or what Minkowski’s equation postulates. --- Therefore, by assuming that the universe has four dimensions that are related by Minkowski's formula the speed of light appears as a constant and it does not need to be assumed to be constant as in Einstein's original approach to special relativity. Notice that c is not explicitly required to be the speed of light. It is a consequence of Maxwell's electrodynamics that light travels with c. There is no such requirement inherent in special relativity. --- Another explanation may have to do with “dependence on definition of units” as stated below from http://en.wikipedia.org/wiki/Status_...ial_relativity. But I am not sure where “but then the invariance of c is non-trivial” would come from. --- Because of the freedom one has to select how one defines units of length and time in physics, it is possible to make one of the two postulates of relativity a tautological consequence of the definitions, but one cannot do this for both postulates simultaneously because when combined they have consequences which are independent of one's choice of definition of length and time. For instance, if one defines units of length and time in terms of a physical object (e.g. by defining units of time in terms of transitions of a caesium atom, or length in terms of wavelengths of a krypton atom) then it becomes tautological that the law determining that unit of length or time will be the same in all reference frames, but then the invariance of c is non-trivial. Conversely, if one defines units of length and time in such a way that c is necessarily constant, then the second postulate becomes tautological, but the first one does not; for instance, if the length unit is defined in terms of the time unit and a predetermined fixed value of c, then there is no a priori reason why the number of wavelengths of krypton in a unit of length will be the same in all reference frames (or even in all orientations). --- There is yet another possible explanation at http://en.wikipedia.org/wiki/Status_...ial_relativity. --- In fact Maxwell's equations combined with the first postulate of special relativity can be used to deduce the second postulate. Actually electromagnetism is greatly simplified by relativity, as magnetism is simply the relativistic effect obtained when the simple law of electrostatics is put into a relativistic Universe. --- Perhaps Einstein did not want SR to depend on Maxwell’s equation and as such he would be able to show that Maxwell’s equation is a logical consequence of SR. But again, I don’t know how one would come to conclude “magnetism is simply the relativistic effect obtained when the simple law of electrostatics is put into a relativistic Universe.” So it seems that we are very close to an agreement. Nevertheless, in addition to the mathematical consequence of Maxwell equation plus the principle of relativity, I’d like to know what mechanics is behind light to allow it travel that way, or “how does light travel at an invariant speed to anyone and everyone”? :) EDIT: Just noticed that the last "explanation" actually is problematic given that Minkowski's formula is needed in addition to SR's 1st postulate to derive 'c' in SR. |
| Jan7-08, 05:45 PM | #55 |
Ming,
The postulate is supported by the fact that the laws of physics require it to avoid contradictions. Also, is the Wiki really the best source you have ? I must say I find your arguments incomprehensible but I don't think you understand relativity at all. |
| Jan7-08, 06:11 PM | #56 |
Mentor
What I am talking about is this: |
| Jan7-08, 06:20 PM | #57 |
Mentor
| Jan7-08, 08:06 PM | #58 |
If the theory is based on the first and second postulates, then the speed of light 'c' is guaranteed, but the abstract mathematical manipulations will not reveal the 'how' or 'why'. The purpose of the theory is to produce numbers that agree with measurements/perceptions by the observer. To explain 'why', you have to analyze the behaviour in terms of physical processes. There is an answer to this, just as there is for time dilation.
| Jan7-08, 10:06 PM | #59 |
My original question is about the (physical) mechanism/process, not philosophy/abstract-math. |
| Jan7-08, 10:10 PM | #60 |
| Jan7-08, 10:17 PM | #61 |
| Jan8-08, 12:57 AM | #62 |
| Jan8-08, 10:05 AM | #63 |
Note that the case v1 = c cannot however studied in SR because v1 is the speed of the moving ref. frame S' with respect to the stationary ref. frame S (v2 is the speed of the object with respect to S') and we know that no ref. frame with that speed can exist. |
| Jan8-08, 09:45 PM | #64 |
The solution, Einstein explained, lay in a reconception of the idea of time. |
| Jan20-08, 11:43 AM | #65 |
I'd say the underlying properties of space-time is a by-product of the invariance of the speed of light which is a postulate of SR |
| Jan20-08, 11:53 AM | #66 |
Mentor
| Jan20-08, 12:47 PM | #67 |
It was Minkowski who pointed out how important the geometry of spacetime was. Einstein himself did not at first seem to think geometrically about spacetime. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why does light have invarient speed?
| Thread | Forum | Replies | ||
| Can photons be accelated or do they always travel at one speed (speed of light)? | General Physics | 25 | ||
| Real time effects of light, light speed, and the sun? | General Astronomy | 4 | ||
| Speed of light Schmeed of light: things can travel faster | Special & General Relativity | 13 | ||
| Does the Speed of Light Change depending on different Light Frequencies? | General Physics | 15 | ||
| Why does light have invarient speed? | Special & General Relativity | 3 | ||
