Calculating Angular Momentum of a Skater on a Spinning Disk
  • Thread starter Thread starter gupster
    Dynamics Spinning
gupster
Practice question for a general physics exam - I'm a 4th year undergraduate but have mostly taken astrophysics courses this year so am a bit stuck going back to general physics...
A skater spins with angular velocity \omega = 6 rad/s with his arms extended. How fast will he spin with his arms by his sides? Treat the skater's body as a uniform cylinder of radius R = 20cm, approximate his arms as thin uniform rods of length L = 70 cm and mass m = 4.5 kg. His total mass excluding arms is M = 70 kg.
After ceasing to spin the skater now steps onto the outer edge of a large uniform disk of radius R_{disk} = 2.5 m and mass M_{disk} = 500 kg. Assume that the disk is mounted on a frictionless bearing with a vertical axis of rotation and is initially at rest. If the skater begins skaing around the edge of the disk at a speed of 2 m/s how fast does the disk turn and what is its angular momentum?
For a body of mass M with a moment of inertia I about an axis through its ventre of mass the
moment of inertia about a parallel axis a distance d from the first is I + Md^{2}
The moment of inertia of a uniform cylinder of mass M, radius R and length L rotating about its axis is \frac{1}{2}ML^{2}
I think I've done the first part. I called the situation with the arms outstretched 1 and arms by his side 2 so
I_{1} = \frac{1}{2}MR^{2} = \frac{1}{2}(79)(0.2)^{2} = 1.58
I_{2} = \frac{1}{2}MR^{2} + 2(\frac{1}{12}ML^{2} +Md^{2})= \frac{1}{2}(70)(0.2)^{2} + 2(\frac{1}{12}(45)(0.7)^{2} + (4.5)(0.55)^{2})= 7.798
E = \frac{1}{2}I_{1}\omega_{1}^{2} = \frac{1}{2}I_{2}\omega_{1}^{2}
\omega_{2} = 13.33 rad/s
Its the second part I'm struggling with. I've said
v = r\omega and using conservation of momentum
v_{disk} = \frac{m_{s}v_{s}}{m_{disk}} = 0.316 m/s
\omega_{s} = \frac{v_{s}}{r} = 0.83 rad/s
Is this right because I'm not convinced...
Looks like you reversed your notation. I_1 looks like an attempt at I for arms by his side.
What's the I for the torso? That should not change.
What's the I for the arms in each case?
Energy is not conserved, but something else is.
Oops yeah that notation is the wrong way round. I can't seem to edit my original post though.
So I do the moment of inertia for body+arms for each case and then assume momentum is conserved? That's the only other thing I can think of that is conserved! I'll have a go at that now then. I feel like I'm being really stupid not being able to do this but I was taught this stuff 3 and a half years ago and I don't think I ever fully grasped it!
Yes. And it's angular momentum that's conserved. Assuming no friction, then there's no external torque and thus angular momentum is conserved.
I've hit a snag when trying to calcuate the moment of inertia for when his arms are by his side because I don't know the radius of his arms. I've said
I_arm = I + Md^2 where I = MR^2 and d is the distance from the axis i.e. R_body+R_arm
The arms are modeled as thin rods, not cylinders. Radius is small and irrelevant.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
