| New Reply |
Help Design a Human-Powered Helicopter |
Share Thread | Thread Tools |
| May20-10, 10:41 AM | #154 |
| May20-10, 10:33 PM | #155 |
......sure, whatever you say . Honestly though, stability of a coaxial is a poor, and the actuation lag time constants are high. In short, you save weight but gain significant stability and control problems.
| May21-10, 06:26 AM | #156 |
if the design of the component does nothing but store energy, and nothing more, then it does IMHO violate the rules. I am not saying that, what I am saying is the flight has specific time goals, but if it takes 2 men (or women) 4 hours to bring the whole machine up to speed, then it is not an energy storage device. the idea is that you can only apply x amount of work/time so if you can not change the power you (as a person) can put out, then the only way to get the power you need is more time. because the counter rotating rotors are critical to the aircraft, and do the lifting once proper rotational speed is reached, they are not storing the energy, it is being used. The counter rotating rotors will add a natural "gyro stability" by not needing to offset the rotation with a tail rotor. You control the amount of lift by the amount of power you split between the two, but both are doing the work. simpler example: 2 dc electric motors connected together by their leads together. if you spin one, the other will turn. no energy storage. add a battery in between, charge it with one motor, and run the other. energy storage
dr |
| May21-10, 10:07 AM | #157 |
| May21-10, 10:10 AM | #158 |
a little less cryptic response would sure help action-reaction works the same regardless of rpm dr |
| May21-10, 10:13 AM | #159 |
| May21-10, 11:04 AM | #160 |
my discussion and input was mainly geared towards "energy storage"
but if coaxial rotors are so unstable, how come they work fine in rc toys? much easier to fly than single rotor rc's dr |
| May21-10, 11:43 AM | #161 |
| May21-10, 02:52 PM | #162 |
| May21-10, 02:54 PM | #163 |
Coaxials are the best in terms of reduced structural weight, but they are like trying to balance an upside down broom by its handle. If you can figure out stability, you will have a significantly lighter vehicle. Or you can go the quad rotor route as the Japanese did, but now you have huge structural weights. There is no easy answer. Do you want to try to make really light weight structures (that's not easy), or can you come up with a clever control scheme (that's not easy either)? Either choice has significant challenges. |
| May21-10, 10:35 PM | #164 |
So I got back home and found that NASA-TN. It's not on a coaxial rotor, but a single reaction drive rotor. However, stability of a coaxial rotor will still be a problem due to the excessively low rotor RPMs.
References [1]NASA TM-101029 |
| May22-10, 09:35 AM | #165 |
I am impressed by the feat of engineering, but god, what of the fail-safe? You get off the ground, and presumably your "out" is a parachute, but there is a large range in which it will not deploy in time. This seems... odd.
I suppose you could spend a few hours spinning up a flywheel, but that is dangerous too if you're sitting near it. I would much rather consider dirigibles for human powered flight. |
| May22-10, 10:26 AM | #166 |
It's not legal to have flywheels, or to spin up rotors before hand, as per the rules. As for a parachute, why would you need one at 10 feet (if you run the numbers, you'll find that a person can't fly any higher than that)? There is no danger in those spinning rotors, because they max at around 20-25 rpm.
| May22-10, 03:49 PM | #167 |
I'm not saying that this is some terrible risk, but falling 10 feet and not being hurt requires luck, or preparation and control in the fall. I just don't see the point of removing energy storage in some form, even though I know the rules are the rules. |
| May22-10, 05:17 PM | #168 |
. As for the energy storage, that's because the rules are so that one designs a good vehicle. Storing energy would be a cop-out.
| May22-10, 05:44 PM | #169 |
| May23-10, 08:34 AM | #170 |
| New Reply |
| Thread Tools | |
Similar Threads for: Help Design a Human-Powered Helicopter
| Thread | Forum | Replies | ||
| design a human-powered machine... | Introductory Physics Homework | 5 | ||
| Solar Powered Helicopter? | Aerospace Engineering | 31 | ||
| Human powered circumnavigation | Earth | 0 | ||
| Human powered still - Nichrome wire | Electrical Engineering | 6 | ||
