Jacquesl
- 136
- 1
How to separate CO2 into C and O2, how can this be done, will this require, much energy?
Heat it, it takes 393.5 kJ/mol.Jacquesl said:How to separate CO2 into C and O2, how can this be done, will this require, much energy?
Oxygen is produced when light is present.
you could heat CO2 over a catalyst of iron doped zeolite and hydrogen to produce water and ethylene
Jacquesl said:If hydrogen exist 75% in space, can it be used by tapping into that source
PaulS1950 said:Don't the CO2 scrubbers in re-breathers and in spacecraft use activated charcoal to capture the carbon and release the oxygen?
Borek said:Speaking of crackpottery... you can use tweezers to separate carbon and oxide. Just pull in opposite directions.
This statement makes no sense. An AFM does not, for instance, shoot out a laser beam at the sample.Eriqire said:If you used a focused light beam (laser) it would (theoretically) be plausible (with an atomic force microscope)
Gokul43201 said:This statement makes no sense. An AFM does not, for instance, shoot out a laser beam at the sample.
chemisttree said:Oxygen can be isolated but carbon monoxide is the final carbon containing product.
DrStupid said:How about the Boudouard reaction as a second step:
1. 2 CO2 -> 2 CO + O2
2. 2 CO -> CO2 + C
chemisttree said:Sure, if your goal is to produce carbon.
DrStupid said:According to the title of this thread it is.
chemisttree said:Of course it is but you were responding to my post which featured links where the final carbon-containing species was CO (as I indicated).
DrStupid said:And because CO is only half the way to carbon I suggested a second step to complete the separation of CO2 into C and O2.
