Calculation on Price Elasticity of Demand problem Need Advices .
The discussion revolves around calculating the price elasticity of demand and the effects of changes in disposable income and advertising expenditures on demand using the provided demand function Q = 2.0 P^-1.33Y^2.0A^0.50. To find the price elasticity of demand, the formula involves taking the partial derivative of Q with respect to P, then multiplying by P/Q. For the percentage increase in demand due to a 3% increase in disposable income, the income elasticity of demand is calculated similarly, followed by multiplying the result by 3. A similar approach applies to determine the percentage increase in demand from a 5% increase in advertising expenditures, using the advertising elasticity of demand. The discussion emphasizes the need for clarity in calculations and the application of derivatives, suggesting that a graph is not necessary for solving these problems.
DreamBell
Calculation on Price Elasticity of Demand problem ... Need Advices ...
Give following demand function:
Q = Quantity demanded (Thousads of units)
P = Prices ($/Unit)
Y = Disposable income per capita ($ thousands)
A = Advertising expenditures ($ thousands)
When P = $2/unit, Y = $8 (i.e. $8000), and A = $25 (i.e. $25000)...
1. Price Elasticity of demand
2. The approximate percentage increase in demand if disposable income percentage increased by 3%.
3. The approximate percentage increase in demand if Advertising Expenditure are increased by 5%.
Well, i really not so understand how to resolved the ab0ve question. Is that i need to draft a graft in order to get the answer ?
Hopefully hav some one professional here to guide me on this kind of question .
regards,
Dream Bell
I have no idea about the economy part of the question, but you will not probably get much help, as your post is ambiguous and not clear. I can only guess that equation for Q is given, and points 1-3 are things that you are expected to calculate.
If so, 2 & 3 looks like simple plug and chug.
P = Prices ($/Unit)
regards,
Dream Bell
For (1) use the definition of price elasticity. This should involve a partial derivative. For 2 and 3 formula use the definition of percent change. (Y2-y1)/Y1*100%. Less formula (for example in 2) you could simply replace Y by 1.03Y and see how this effects Q.
P = Prices ($/Unit)
regards,
Dream Bell
This is almost identical to your previous question, but the derivative is just a little more complicated. Still uses the same rule, though.
For number 1, the equation for price elasticity of demand is Ep(Q) = Q'(P) * P/Q.
Try to solve for Q'(P) on your own using the formula I gave you in your other post (given Ax^B, d(x) = A*B*x^B-1, and you get to hold Y and A constant when taking derivative with respect to P).
From there, you just plug price in for P, and solve for Q given the values in the problem, which you plug into the denominator, and multiply by the derivative with respect to P. This will give you a number between 0 and infinity (typically between 0 and 2), which is the price elasticity of demand.
For number 2, you first need to find the income elasticity of demand. This is Ey(Q) = Q'(Y) * Y/Q, and is found the exact same way as price elasticity, just w.r.t. a different variable. Multiply the result by 3 to get the percent change in demand that follows a 3% change in income.
For number 3, you are finding the advertising elasticity of demand. This is Ea(Q) = Q'(A) * A/Q. See the trend here? Multiply that result by 5 to get the change after a 5% change in advertising expenditures. I'm sorry if this isn't very clear, but hopefully it helps.
Good luck.
Good luck.
Ah, I missed the word approximate.
Thread 'RIP George F. Smoot III (1945-2025)'
https://en.wikipedia.org/wiki/George_Smoot https://physics.berkeley.edu/people/faculty/george-smoot-iii https://apc.u-paris.fr/fr/memory-george-fitzgerald-smoot-iii https://elements.lbl.gov/news/honoring-the-legacy-of-george-smoot/ https://www.nobelprize.org/prizes/physics/2006/smoot/facts/ https://www.aps.org/publications/apsnews/200611/nobel.cfm https://inspirehep.net/authors/988263 Structure in the COBE Differential Microwave Radiometer First-Year Maps (Astrophysical Journal...
15K
