How Is Gravitational Potential Energy Calculated for a Skier on a Ski Lift?
To calculate the gravitational potential energy of a skier on a ski lift, the correct formula involves determining the vertical displacement (delta y) rather than the total distance traveled by the lift. The skier's weight is multiplied by the gravitational acceleration and the vertical height, which is found using the sine of the lift's angle. The initial calculation incorrectly used the total distance instead of the vertical height. The corrected formula yields a gravitational potential energy of approximately 4.13 x 10^5 J. Accurate calculations must account for the angle of the lift to determine the correct potential energy.
jbjohnybaker
A 68.5-kg skier rides a 2.56-km ski lift from the base of a mountain to the top. The lift is at an angle of 13.9° to the horizontal. Determine the skier’s gravitational potential energy at the top of the mountain relative to the base of the mountain.
Eg= mg delta y
eg = (68.5)(9.81)(2560)
= 1720281.6 J
The answer in the textbook is 4.13x10^5 J :S
hello,
you have not accounted for the angle. the ski lift does not go straight up, it goes up a slope.
eczeno said:
hello,
I have been taught that "the value of delta y is the vertical displacement of the object. This means that the horizontal path of an object follows in changing its vertical height is not significant" :S
that is correct, but you have the wrong value for delta y. the lift travels a total distance of 2.56 km, but that is not the change in altitude, that is how long the cables are.
is it right?
eg = (68.5)(sin13.5)(9.81)(2560)
looks good.
thank you very much.
cheers.
