Is a Quadratic Equation with b=0 or c=0 Still a Quadratic?
A quadratic equation is defined as having the form y = ax^2 + bx + c, where a is not equal to zero. Even if c = 0, resulting in y = ax^2 + bx, it remains a quadratic equation. Similarly, if b = 0, leading to y = ax^2, it is still classified as a quadratic equation due to the presence of the x^2 term. The key factor is that the coefficient a must not be zero for it to retain its quadratic classification. Thus, both cases of b = 0 and c = 0 still qualify as quadratic equations.
LearninDaMath
A quadratic equation has the form y = ax^2 + bx + c. However, if c = 0, then y = ax^2 + bx. Is it still called a quadratic equation? And if b = 0 so that y = ax^2, is it still given the title of quadratic equation?
I would guess yes since it still has a power of 2 and is a parabola. Is this correct?
Mathematics news on Phys.org
What you're showing is a quadratic function. A quadratic equation in standard form looks like this:
ax2 + bx + c = 0
ax2 + bx = 0 is still a quadratic equation. The only restriction is that a \neq 0.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
