Coal-steam electricity generation
The discussion focuses on the operation of a coal-fired steam power plant using the ideal Rankine cycle. It is determined that one reheat stage is sufficient to maintain the steam quality above 88.2%, and the thermal efficiency of the plant is calculated at approximately 38.6%. The user seeks guidance on calculating the annual sulfur dioxide emissions from the plant, given its generating capacity and boiler efficiency. They express uncertainty about how to compute the mass of coal needed and how to apply the efficiencies for heat requirements. The conversation highlights the need for clarity in thermodynamic calculations and their implications for emissions.
hdr
A coal-fired steam power plant operates on the ideal Rankine cycle. Feedwater from the
condenser at P1
= 10 kPa is pumped to the boiler at P2
= P3
= 20 MPa, where it is
superheated and exits the boiler at T3
= 550 °C.
The moisture content in the turbine is not to exceed 12% (i.e. steam quality is to be
maintained above x = 0.88 throughout the turbine). Up to two reheat stages can be added to
the steam cycle to satisfy this requirement.
If needed, one stage can be added to reheat the steam to T5
= 525 °C at P4
= P5
= 10 MPa. If
more reheating is required, a second stage can be added to reheat the steam to T7
= 500 °C at
P6
= P7
= 2.5 MPa.
(a). How many reheat stages are required for this power plant (no reheat, single reheat, or
double reheat)? Provide calculations in support of your answer.
(b). What is the thermal efficiency ηth
of the power cycle?
(c). Determine the annual emission of sulfur dioxide, mSO2
, in metric tons, from this power
plant, if the net generating capacity of the plant is 600 MW, and the boiler is 88%
efficient in transferring combustion heat into the feedwater superheat and steam reheat
stages. The boiler burns, to completion, Power River Basin coal that has a heating value
of 22,800 kJ/kg and contains 0.46 wt% sulfur.
Assume that all of the sulfur content of the coal is emitted as SO2
in the combustion flue
gas, and that the coal-burning plant has a capacity factor of 0.85; i.e. the boiler is
operational for 85% of the hours in one calendar year. (1 metric ton = 1000 kg)
Thermodynamics energy balance equations
I completed the first 2 parts of the problem and I found out that one reheating stage is enough to active a steam quality more than 88.2%. I also calculated the thermal efficiency of 38/6% of this power plant.
My question is about part 3. How can I approach?
Seems like that's easier than what you've done already - just calculate the total amount of electricity generated, work back through the efficiencies for the heat required, get the mass of coal and multiply out the fraction of sulfur into SO2.
I am sorry this comes from my bad background in chemistry, I get scared whenever feel that chemistry is involved! So the total electricity generation in a year is 600MW*365*24*3600= 18.9216*10^9 MW/year
I am not sure how to calculate the mass of the coal and as used the efficiencies for the heat required? Can you explain more please?
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
