New Reply
Finding the equation of a plane passing through 3 points
Share Thread Thread Tools
Mar31-12, 06:37 PM   #1
1. The problem statement, all variables and given/known data
Find the equation of the plane passing through point A(2,1,0), B(3,-1,5) and C(2,2,1)
2. Relevant equations
Um..I don't know?
3. The attempt at a solution
Vector AB=(3 -1 5)^T-(2 1 0)^T=(1 -2 5)^T
Vector AC=(2 2 1)^T-(2 1 0)^T=(0 1 1)^T
perpendicular vector n= vector ABxvector AC=(-2*1-5*1 5*0-1*1 1*1--2*0)^T=(-7 -1 1)
since n=(a b c)^T will give a plane with equation ax+by+cz=d, I had assumed the equation of the plane would therefore be -7x-y+z=d, but it turns out it's actually 7x+yx-z=15
Why are the signs inverted? (I sort of missed a few classes so I may be unaware of some fundamental concepts here)
and how do I find d (which turns out to be 15)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar31-12, 06:43 PM   #2
Mentor
Quote by Luscinia View Post
Um..I don't know?
What do you get if you multiply both sides of 7x+y-z=15 by -1 ?
Mar31-12, 08:24 PM   #3
Getting to "d": take one point and solve for d to put it in the plane. If you use a different d, you get a parallel plane. So if you generate d for one point, you can check it with another (both of the others, if you're nervous ).
Apr1-12, 04:52 PM   #4
Oh man, can't believe I didn't see that. Thanks!
New Reply
Tags
finding equations, linear algebra, plane and vector, plane equation
Thread Tools
Similar Threads for: Finding the equation of a plane passing through 3 points
Thread Forum Replies
Finding equation of a plane passing through a point with given direction vectors Calculus & Beyond Homework 1
Linear Algebra - Finding the equation of a plane from 3 points Calculus & Beyond Homework 2
Equation of a plane passing through a Point Calculus & Beyond Homework 1
Finding cartesian equation of plane from 3 points Calculus & Beyond Homework 4
the equation of a plane perpendicular to a vector and passing through a given point? Calculus 7
