| New Reply |
Pressure due to volume change |
Share Thread | Thread Tools |
| Apr22-12, 12:49 PM | #1 |
Hi,
I have a closed system of fixed volume with an piston pump attached. The medium is air and the initial environmental condition are at standard atmospheric. I would like to know the formulas to use that would provide me with the new pressure when the piston is at top dead center (i.e. traveled a full stroke). Would I be correct in assuming that temperature is negligible when no heat (or fuel) is supplied to the system during the cycle? Thanks |
| Apr22-12, 03:07 PM | #2 |
If you know the initial volume and pressure, you would use P1V1=P2V2, where P1 and V1 are the initial pressure and volume and the other side of the equation is the pressure and volume after the piston has moved.
I would also say that temperature is negligible. It would change slightly, but it's not relevant because it's a result of the pressure change. |
| Apr23-12, 11:35 AM | #3 |
| Apr23-12, 06:54 PM | #4 |
| Apr24-12, 01:27 PM | #5 |
| New Reply |
| Thread Tools | |
Similar Threads for: Pressure due to volume change
| Thread | Forum | Replies | ||
| HELP!!! Pressure Change for equation without volume | Biology, Chemistry & Other Homework | 2 | ||
| Required change in pressure to change volume | Introductory Physics Homework | 5 | ||
| Pressure/Volume change | Introductory Physics Homework | 1 | ||
| rates of pressure and volume change | Introductory Physics Homework | 1 | ||
| volume expansion and pressure change | Introductory Physics Homework | 8 | ||
