New Reply
Transformer currents in primary and secondary question
Share Thread
May27-12, 10:33 PM   #1
I'm reviewing transformers and I have some confusion over the current
s is for secondary and p is for primary
I know that
Vs = Vp(Ns/Np)
and
Ip = Is(Ns/Np)
So when you have a load across the secondary terminal you get your current through Vs/Rload.
But does this mean for current in the primary coil, it has nothing to do with the inductance value or resistance (if I added a resistor before the inductor in the primary section)? V/Z = I does not work here?
If this is true what would the current be if I left the secondary terminal open so no current will flow. What do i use to calculate current in the primary coil? Is it affected by the inductance value then?
thanks in advance
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
May27-12, 10:59 PM   #2
Recognitions:
Quote by KrNx2Oh7 View Post
I know that
Vs = Vp(Ns/Np)
and
Ip = Is(Ns/Np)
thanks in advance
Those formulas are for ideal transformers. There will be a current in the primary due to the load in the secondary, but there will also be a current due to the inductance of the primary winding.
It is just a coil and it has to have some value of inductance and so it has a reactance which will allow a certain amount of current to flow from the supply.
Cheap transformers are sometimes wound on inadequate iron formers and so don't have enough inductance or reactance to stop a relatively large current flowing even if there is no load.
New Reply
Similar discussions for: Transformer currents in primary and secondary question
Thread Forum Replies
Transformer Primary and secondary currents Engineering, Comp Sci, & Technology Homework 1
Finding Primary and Secondary Currents? Electrical Engineering 1
Transformer primary to secondary short? Electrical Engineering 12
Transformer questions - primary, secondary, gaaaah!! Introductory Physics Homework 2
Primary and Secondary Voltages In A Transformer Introductory Physics Homework 7
